Design Span (L): 13.75 ft.
Clear Span: 13.50 ft.
Total Span: 14.00 ft.
Live Load: 40 plf
Dead Load: 15 plf
Selfweight: 45.3 lbs
Dist. Selfweight: 3.30 plf
Total Weight: 46.1 lbs
Beam Design 2021A709
11/30/2021 1
11/30/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [13.88 x (165.00 + 3)] x (12 in./ft.)3 = 1.35 ft3
Volumespan = N[A x L] = 1 x [13.88 x 165.00] x (12 in./ft.)3 = 1.32 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 1.35 = 46.1 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 1.32 = 45.3 lbs
40 plf
15 plf
ws = 3.30 plf
13.75 ft.
13.50 ft.
408.07 lbs
408.07 lbs
11/30/2021 3
fb = = 772.9 psi
 fb = 772.9 psi < Fbx' = 990.0 psi  (CSI = 0.78)   ➜  OK
11/30/2021 4
fv* = = 38.47 psi
 fv* = 38.47 psi < Fvx' = 180.00 psi  (CSI = 0.21)   ➜  OK
fv = = 43.33 psi
 fv = 43.33 psi < Fvx' = 180.00 psi  (CSI = 0.24)   ➜  OK
11/30/2021 5
ΔLL = = 0.20 in.
(L/d)LL = 165.00 / 0.20 = 812
 ΔLL = 0.20 in = L/812 < L/360   ➜  OK
ΔTL = = 0.30 in.
(L/d)TL = 165.00 / 0.30 = 557
 ΔTL = 0.30 in = L/557 < L/240   ➜  OK
fc⊥ = = 90.7 psi
 fc⊥ = 90.7 psi < Fc⊥x' = 625.00 psi  (CSI = 0.15)   ➜  OK
11/30/2021 6
