Beam Design - 515 N Florida Street, Arlington, VA
Design Span (L): 7.63 ft.
Clear Span: 7.38 ft.
Total Span: 7.88 ft.
Live Load: 510 plf
Dead Load: 226 plf
Selfweight: 61.1 lbs
Dist. Selfweight: 8.02 plf
Total Weight: 63.1 lbs
Notes: Construction
Beam Design 101
11/30/2021 1
Beam Design 101
11/30/2021 2
Volumetotal = N[A x (L + lb)] = 2 x [16.88 x (91.50 + 3)] x (12 in./ft.)3 = 1.85 ft3
Volumespan = N[A x L] = 2 x [16.88 x 91.50] x (12 in./ft.)3 = 1.79 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 1.85 = 63.1 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 1.79 = 61.1 lbs
510 plf
226 plf
ws = 8.02 plf
7.63 ft.
7.38 ft.
7.88 ft.
2929.56 lbs
2929.56 lbs
Beam Design 101
11/30/2021 3
fb = = 1025.4 psi
 fb = 1025.4 psi < Fbx' = 1035.0 psi  (CSI = 0.99)   ➜  OK
Beam Design 101
11/30/2021 4
fv* = = 95.07 psi
 fv* = 95.07 psi < Fvx' = 207.00 psi  (CSI = 0.46)   ➜  OK
fv = = 126.07 psi
 fv = 126.07 psi < Fvx' = 207.00 psi  (CSI = 0.61)   ➜  OK
Beam Design 101
11/30/2021 5
ΔLL = = 0.07 in.
(L/d)LL = 91.50 / 0.07 = 1343
 ΔLL = 0.07 in = L/1343 < L/360   ➜  OK
ΔTL = = 0.10 in.
(L/d)TL = 91.50 / 0.10 = 921
 ΔTL = 0.10 in = L/921 < L/240   ➜  OK
fc⊥ = = 325.5 psi
 fc⊥ = 325.5 psi < Fc⊥x' = 625.00 psi  (CSI = 0.52)   ➜  OK
Beam Design 101
11/30/2021 6
