Grade: SPF No.2
Design Span (L): 5.88 ft.
Clear Span: 5.75 ft.
Total Span: 6.00 ft.
Bearing (lb): 1.5 in.
Live Load: 450 plf
Dead Load: 90 plf
Selfweight: 32.9 lbs
Dist. Selfweight: 5.61 plf
Total Weight: 33.6 lbs
Beam Design 2021A702
11/29/2021 1
11/29/2021 2
Volumetotal = N[A x (L + lb)] = 2 x [13.88 x (70.50 + 1.5)] x (12 in./ft.)3 = 1.16 ft3
Volumespan = N[A x L] = 2 x [13.88 x 70.50] x (12 in./ft.)3 = 1.13 ft3
Total Weight (WT) = ρw x Volumetotal = 29.10 x 1.16 = 33.6 lbs
Self Weight (WS) = ρw x Volumespan = 29.10 x 1.13 = 32.9 lbs
450 plf
90 plf
ws = 5.61 plf
5.88 ft.
5.75 ft.
1636.82 lbs
1636.82 lbs
11/29/2021 3
lu = Unbraced Length = 5.875 ft.
lu/d = = 7.62
le = 1.63lu + 3d = 1.63(70.5) + 3(9.25) = 142.66 in. = 11.89 ft.  (NDS Table 3.3.3)
Rb = = 12.11
 Rb = 12.11 < 50   ➜  OK
11/29/2021 4
FbE = = 4173.83 psi
Fbx* = Fbx(CD)(CM)(Ct)(CF)(Ci)(Cr) = (875)(1.15)(1)(1)(1.1)(1)(1) = 1106.88 psi
CL =   = 0.983
Fbx' = (875)(1.15)(1)(1)(0.983)(1.1)(1)(1) = 1087.7 psi
fb = = 660.3 psi
 fb = 660.3 psi < Fbx' = 1087.7 psi  (CSI = 0.61)   ➜  OK
fv* = = 63.90 psi
 fv* = 63.90 psi < Fvx' = 155.25 psi  (CSI = 0.41)   ➜  OK
fv = = 86.63 psi
 fv = 86.63 psi < Fvx' = 155.25 psi  (CSI = 0.56)   ➜  OK
11/29/2021 5
ΔLL = = 0.04 in.
(L/d)LL = 70.50 / 0.04 = 1619
 ΔLL = 0.04 in = L/1619 < L/360   ➜  OK
ΔTL = = 0.05 in.
(L/d)TL = 70.50 / 0.05 = 1335
 ΔTL = 0.05 in = L/1335 < L/240   ➜  OK
fc⊥ = = 363.7 psi
 fc⊥ = 363.7 psi < Fc⊥x' = 425.00 psi  (CSI = 0.86)   ➜  OK
11/29/2021 6
