Size: 5.125 x 12
Design Span (L): 4.38 ft.
Clear Span: 4.00 ft.
Total Span: 4.75 ft.
Bearing (lb): 4.5 in.
Live Load: 0 lbs
Dead Load: 13650 lbs
Selfweight: 63.1 lbs
Dist. Selfweight: 14.42 plf
Total Weight: 68.5 lbs
Defl. Limits: 480|360
Beam Design 2021A7
1/3/2021 1
b = 5.125 in.
Beam Design 2021A7
1/3/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [61.50 x (52.50 + 4.5)] x (12 in./ft.)3 = 2.03 ft3
Volumespan = N[A x L] = 1 x [61.50 x 52.50] x (12 in./ft.)3 = 1.87 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 2.03 = 68.5 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 1.87 = 63.1 lbs
0 lbs
13650 lbs
  ws = 14.42 plf
4.38 ft.
4.00 ft.
4.75 ft.
6859.24 lbs
6859.24 lbs
Beam Design 2021A7
1/3/2021 3
lu = Unbraced Length = 4.375 ft.
lu/d = = 4.38
le = 1.8lu = 1.8(52.5) = 94.50 in. = 7.88 ft.  (NDS Table 3.3.3)
Rb = = 6.57
 Rb = 6.57 < 50   ➜  OK
Beam Design 2021A7
1/3/2021 4
FbE = = 23625.17 psi
Fbx* = Fbx(CD)(CM)(Ct) = (2400)(0.9)(1)(1) = 2160.00 psi
CL =   = 0.995
CL = 0.995 < CV = 1.0
Fbx' = (2400)(0.9)(1)(1)(0.995) = 2149.2 psi
fb = = 1459.9 psi
 fb = 1459.9 psi < Fbx' = 2149.2 psi  (CSI = 0.68)   ➜  OK
Fvx' = (265)(0.9)(1)(1) = 238.50 psi
fv* = = 166.88 psi
Beam Design 2021A7
1/3/2021 5
 fv* = 166.88 psi < Fvx' = 238.50 psi  (CSI = 0.70)   ➜  OK
fv = = 167.23 psi
 fv = 167.23 psi < Fvx' = 238.50 psi  (CSI = 0.70)   ➜  OK
LL Allowable: L/480
TL Allowable: L/360
ΔLL =   =   = 0.00 in.
(L/d)LL = 52.50 / 0.00 = ∞
 ΔLL = 0.00 in = L/∞ < L/480   ➜  OK
ΔTL =   =   = 0.03 in.
(L/d)TL = 52.50 / 0.03 = 1690
 ΔTL = 0.03 in = L/1690 < L/360   ➜  OK
Beam Design 2021A7
1/3/2021 6
Ab = b x lb = 5.125 x 4.5 = 23.06 in2
fc⊥ = = 297.4 psi
 fc⊥ = 297.4 psi < Fc⊥x' = 650.00 psi  (CSI = 0.46)   ➜  OK
Beam Design 2021A7
1/3/2021 7
