Grade: SPF SS
Design Span (L): 5.08 ft.
Clear Span: 4.83 ft.
Total Span: 5.33 ft.
Live Load: 1085 plf
Dead Load: 385 plf
Selfweight: 52.0 lbs
Dist. Selfweight: 10.23 plf
Total Weight: 54.6 lbs
Beam Design 2021A698
11/29/2021 1
11/29/2021 2
Volumetotal = N[A x (L + lb)] = 3 x [16.88 x (61.00 + 3)] x (12 in./ft.)3 = 1.87 ft3
Volumespan = N[A x L] = 3 x [16.88 x 61.00] x (12 in./ft.)3 = 1.79 ft3
Total Weight (WT) = ρw x Volumetotal = 29.10 x 1.87 = 54.6 lbs
Self Weight (WS) = ρw x Volumespan = 29.10 x 1.79 = 52.0 lbs
Distributed Self Weight (ws) = = 10.23 plf
1085 plf
385 plf
ws = 10.23 plf
5.08 ft.
4.83 ft.
5.33 ft.
3947.03 lbs
3947.03 lbs
11/29/2021 3
lu = Unbraced Length = 5.083 ft.
lu/d = = 5.42
le = 2.06lu = 2.06(61.0) = 125.65 in. = 10.47 ft.  (NDS Table 3.3.3)
Rb = = 8.36
 Rb = 8.36 < 50   ➜  OK
11/29/2021 4
FbE = = 9454.70 psi
Fbx* = Fbx(CD)(CM)(Ct)(CF)(Ci)(Cr) = (1250)(1.15)(1)(1)(1)(1)(1) = 1437.50 psi
CL =   = 0.991
Fbx' = (1250)(1.15)(1)(1)(0.991)(1)(1)(1) = 1424.9 psi
fb = = 604.4 psi
 fb = 604.4 psi < Fbx' = 1424.9 psi  (CSI = 0.42)   ➜  OK
fv* = = 70.35 psi
 fv* = 70.35 psi < Fvx' = 155.25 psi  (CSI = 0.45)   ➜  OK
fv = = 111.47 psi
 fv = 111.47 psi < Fvx' = 155.25 psi  (CSI = 0.72)   ➜  OK
11/29/2021 5
ΔLL = = 0.02 in.
(L/d)LL = 61.00 / 0.02 = 2998
 ΔLL = 0.02 in = L/2998 < L/360   ➜  OK
ΔTL = = 0.03 in.
(L/d)TL = 61.00 / 0.03 = 2197
 ΔTL = 0.03 in = L/2197 < L/240   ➜  OK
fc⊥ = = 292.4 psi
 fc⊥ = 292.4 psi < Fc⊥x' = 425.00 psi  (CSI = 0.69)   ➜  OK
11/29/2021 6
