Grade: 24F-V8 1.8E DF/DF
Size: 10.75 x 54
Design Span (L): 54.75 ft.
Clear Span: 54.50 ft.
Total Span: 55.00 ft.
Selfweight: 7451.5 lbs
Dist. Selfweight: 136.10 plf
Total Weight: 7485.5 lbs
CV Volume Factor 0.726b - - - - -
Beam Design 2021A695
11/29/2021 1
b = 10.750 in.
d = 54.000 in.
A = 10.750 x 54.000 = 580.50 in.2
Sx = (10.750)(54.000)2/6 = 5224.50 in.3
Sy = (10.750)2(54.000)/6 = 1040.06 in.3
Ix = (10.750)(54.000)3/12 = 141061.50 in.4
Iy = (10.750)3(54.000)/12 = 5590.34 in.4
11/29/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [580.50 x (657.00 + 3)] x (12 in./ft.)3 = 221.72 ft3
Volumespan = N[A x L] = 1 x [580.50 x 657.00] x (12 in./ft.)3 = 220.71 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 221.72 = 7485.5 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 220.71 = 7451.5 lbs
Distributed Self Weight (ws) = = 136.10 plf
  ws = 136.10 plf
54.75 ft.
54.50 ft.
55.00 ft.
8555.24 lbs
8555.24 lbs
11/29/2021 3
CV = = 0.726
CV = 0.726 < CL = 1
Fbx' = (2400)(1.00)(1)(0.8)(0.726) = 1393.8 psi
fb = = 267.7 psi
 fb = 267.7 psi < Fbx' = 1393.8 psi  (CSI = 0.19)   ➜  OK
11/29/2021 4
Fvx' = (265)(1.00)(1)(0.8) = 212.00 psi
fv* = = 18.39 psi
 fv* = 18.39 psi < Fvx' = 212.00 psi  (CSI = 0.09)   ➜  OK
fv = = 22.01 psi
 fv = 22.01 psi < Fvx' = 212.00 psi  (CSI = 0.10)   ➜  OK
11/29/2021 5
ΔLL = = 0.09 in.
(L/d)LL = 657.00 / 0.09 = 7426
 ΔLL = 0.09 in = L/7426 < L/360   ➜  OK
ΔTL = = 0.28 in.
(L/d)TL = 657.00 / 0.28 = 2387
 ΔTL = 0.28 in = L/2387 < L/240   ➜  OK
Ab = b x lb = 10.75 x 3 = 32.25 in2
fc⊥ = = 265.3 psi
 fc⊥ = 265.3 psi < Fc⊥x' = 520.00 psi  (CSI = 0.51)   ➜  OK
11/29/2021 6
