Grade: SPF No.2
Design Span (L): 6.25 ft.
Clear Span: 6.00 ft.
Total Span: 6.50 ft.
Live Load: 1085 plf
Dead Load: 280 plf
Selfweight: 63.9 lbs
Dist. Selfweight: 10.23 plf
Total Weight: 66.5 lbs
Beam Design 2021A694
11/29/2021 1
11/29/2021 2
Volumetotal = N[A x (L + lb)] = 3 x [16.88 x (75.00 + 3)] x (12 in./ft.)3 = 2.29 ft3
Volumespan = N[A x L] = 3 x [16.88 x 75.00] x (12 in./ft.)3 = 2.20 ft3
Total Weight (WT) = ρw x Volumetotal = 29.10 x 2.29 = 66.5 lbs
Self Weight (WS) = ρw x Volumespan = 29.10 x 2.20 = 63.9 lbs
Distributed Self Weight (ws) = = 10.23 plf
1085 plf
280 plf
ws = 10.23 plf
6.25 ft.
6.50 ft.
4469.50 lbs
4469.50 lbs
11/29/2021 3
lu = Unbraced Length = 6.250 ft.
lu/d = = 6.67
le = 2.06lu = 2.06(75.0) = 154.50 in. = 12.88 ft.  (NDS Table 3.3.3)
Rb = = 9.26
 Rb = 9.26 < 50   ➜  OK
11/29/2021 4
FbE = = 7130.10 psi
Fbx* = Fbx(CD)(CM)(Ct)(CF)(Ci)(Cr) = (875)(1.15)(1)(1)(1)(1)(1) = 1006.25 psi
CL =   = 0.992
Fbx' = (875)(1.15)(1)(1)(0.992)(1)(1)(1) = 998.1 psi
fb = = 848.9 psi
 fb = 848.9 psi < Fbx' = 998.1 psi  (CSI = 0.85)   ➜  OK
fv* = = 89.14 psi
 fv* = 89.14 psi < Fvx' = 155.25 psi  (CSI = 0.57)   ➜  OK
fv = = 127.34 psi
 fv = 127.34 psi < Fvx' = 155.25 psi  (CSI = 0.82)   ➜  OK
11/29/2021 5
ΔLL = = 0.05 in.
(L/d)LL = 75.00 / 0.05 = 1505
 ΔLL = 0.05 in = L/1505 < L/360   ➜  OK
ΔTL = = 0.06 in.
(L/d)TL = 75.00 / 0.06 = 1187
 ΔTL = 0.06 in = L/1187 < L/240   ➜  OK
fc⊥ = = 331.1 psi
 fc⊥ = 331.1 psi < Fc⊥x' = 425.00 psi  (CSI = 0.78)   ➜  OK
11/29/2021 6
