Grade: 24F-V3 1.8E SP/SP
Size: 5.125 x 13.75
Design Span (L): 19.67 ft.
Clear Span: 19.33 ft.
Total Span: 20.00 ft.
Bearing (lb): 4 in.
Selfweight: 355.0 lbs
Dist. Selfweight: 18.05 plf
Total Weight: 361.1 lbs
CV Volume Factor 0.996b - - - - -
Beam Design 2021A692
11/29/2021 1
b = 5.125 in.
d = 13.750 in.
A = 5.125 x 13.750 = 70.47 in.2
Sx = (5.125)(13.750)2/6 = 161.49 in.3
Sy = (5.125)2(13.750)/6 = 60.19 in.3
Ix = (5.125)(13.750)3/12 = 1110.25 in.4
Iy = (5.125)3(13.750)/12 = 154.24 in.4
11/29/2021 2
= 36.89 lbs/ft3
Volumetotal = N[A x (L + lb)] = 1 x [70.47 x (236.00 + 4)] x (12 in./ft.)3 = 9.79 ft3
Volumespan = N[A x L] = 1 x [70.47 x 236.00] x (12 in./ft.)3 = 9.62 ft3
Total Weight (WT) = ρw x Volumetotal = 36.89 x 9.79 = 361.1 lbs
Self Weight (WS) = ρw x Volumespan = 36.89 x 9.62 = 355.0 lbs
Distributed Self Weight (ws) = = 18.05 plf
  ws = 18.05 plf
19.67 ft.
19.33 ft.
1930.56 lbs
1930.56 lbs
11/29/2021 3
CV = = 0.996
CV = 0.996 < CL = 1
Fbx' = (2400)(1.15)(1)(1)(0.996) = 2750.3 psi
fb = = 693.6 psi
 fb = 693.6 psi < Fbx' = 2750.3 psi  (CSI = 0.25)   ➜  OK
11/29/2021 4
fv* = = 35.70 psi
 fv* = 35.70 psi < Fvx' = 345.00 psi  (CSI = 0.10)   ➜  OK
fv = = 40.41 psi
 fv = 40.41 psi < Fvx' = 345.00 psi  (CSI = 0.12)   ➜  OK
11/29/2021 5
ΔLL = = 0.17 in.
(L/d)LL = 236.00 / 0.17 = 1401
 ΔLL = 0.17 in = L/1401 < L/360   ➜  OK
ΔTL = = 0.33 in.
(L/d)TL = 236.00 / 0.33 = 726
 ΔTL = 0.33 in = L/726 < L/240   ➜  OK
Ab = b x lb = 5.125 x 4 = 20.50 in2
fc⊥ = = 94.2 psi
 fc⊥ = 94.2 psi < Fc⊥x' = 740.00 psi  (CSI = 0.13)   ➜  OK
11/29/2021 6
