Beam Design - Uniformed loaded cieling joist dining area
Design Span (L): 16.15 ft.
Clear Span: 15.90 ft.
Total Span: 16.40 ft.
Live Load: 10 plf
Dead Load: 5 plf
Selfweight: 31.6 lbs
Dist. Selfweight: 1.96 plf
Total Weight: 32.1 lbs
Beam Design Jessica Owen 001
11/28/2021 1
11/28/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [8.25 x (193.80 + 3)] x (12 in./ft.)3 = 0.94 ft3
Volumespan = N[A x L] = 1 x [8.25 x 193.80] x (12 in./ft.)3 = 0.93 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 0.94 = 32.1 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 0.93 = 31.6 lbs
10 plf
5 plf
ws = 1.96 plf
16.15 ft.
15.90 ft.
16.40 ft.
139.07 lbs
139.07 lbs
11/28/2021 3
fb = = 877.4 psi
 fb = 877.4 psi < Fbx' = 1170.0 psi  (CSI = 0.75)   ➜  OK
11/28/2021 4
fv* = = 23.49 psi
 fv* = 23.49 psi < Fvx' = 180.00 psi  (CSI = 0.13)   ➜  OK
fv = = 24.90 psi
 fv = 24.90 psi < Fvx' = 180.00 psi  (CSI = 0.14)   ➜  OK
11/28/2021 5
ΔLL = = 0.46 in.
(L/d)LL = 193.80 / 0.46 = 421
 ΔLL = 0.46 in = L/421 < L/360   ➜  OK
ΔTL = = 0.78 in.
(L/d)TL = 193.80 / 0.78 = 248
 ΔTL = 0.78 in = L/248 < L/240   ➜  OK
fc⊥ = = 30.9 psi
 fc⊥ = 30.9 psi < Fc⊥x' = 625.00 psi  (CSI = 0.05)   ➜  OK
11/28/2021 6
