Grade: SP DSS
Selfweight: 102.8 lbs
Dist. Selfweight: 8.75 plf
Total Weight: 105.0 lbs
Beam Design 2021A690
11/28/2021 1
11/28/2021 2
Volumetotal = N[A x (L + lb)] = 2 x [16.88 x (141.00 + 3)] x (12 in./ft.)3 = 2.81 ft3
Volumespan = N[A x L] = 2 x [16.88 x 141.00] x (12 in./ft.)3 = 2.75 ft3
Total Weight (WT) = ρw x Volumetotal = 37.33 x 2.81 = 105.0 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 2.75 = 102.8 lbs
ws = 8.75 plf
1102.50 lbs
1102.50 lbs
11/28/2021 3
fb = = 601.3 psi
 fb = 601.3 psi < Fbx' = 2070.0 psi  (CSI = 0.29)   ➜  OK
11/28/2021 4
fv* = = 40.32 psi
 fv* = 40.32 psi < Fvx' = 201.25 psi  (CSI = 0.20)   ➜  OK
fv = = 47.98 psi
 fv = 47.98 psi < Fvx' = 201.25 psi  (CSI = 0.24)   ➜  OK
11/28/2021 5
ΔLL = = 0.06 in.
(L/d)LL = 141.00 / 0.06 = 2223
 ΔLL = 0.06 in = L/2223 < L/360   ➜  OK
ΔTL = = 0.12 in.
(L/d)TL = 141.00 / 0.12 = 1210
 ΔTL = 0.12 in = L/1210 < L/240   ➜  OK
fc⊥ = = 122.5 psi
 fc⊥ = 122.5 psi < Fc⊥x' = 660.00 psi  (CSI = 0.19)   ➜  OK
11/28/2021 6
