Beam Design - Max Span 24” OC
Design Span (L): 10.50 ft.
Clear Span: 10.00 ft.
Total Span: 11.00 ft.
Live Load: 180 plf
Dead Load: 14 plf
Selfweight: 42.1 lbs
Dist. Selfweight: 4.01 plf
Total Weight: 44.1 lbs
Beam Design B Holmes GWE L9 GWE L9
1/16/2021 1
1/16/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [16.88 x (126.00 + 6)] x (12 in./ft.)3 = 1.29 ft3
Volumespan = N[A x L] = 1 x [16.88 x 126.00] x (12 in./ft.)3 = 1.23 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 1.29 = 44.1 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 1.23 = 42.1 lbs
180 plf
14 plf
ws = 4.01 plf
10.50 ft.
10.00 ft.
11.00 ft.
1089.05 lbs
1089.05 lbs
1/16/2021 3
fb = = 1034.9 psi
 fb = 1034.9 psi < Fbx' = 1035.0 psi  (CSI = 1.00)   ➜  OK
1/16/2021 4
fv* = = 75.90 psi
 fv* = 75.90 psi < Fvx' = 207.00 psi  (CSI = 0.37)   ➜  OK
fv = = 92.40 psi
 fv = 92.40 psi < Fvx' = 207.00 psi  (CSI = 0.45)   ➜  OK
1/16/2021 5
ΔLL = = 0.17 in.
(L/d)LL = 126.00 / 0.17 = 729
 ΔLL = 0.17 in = L/729 < L/180   ➜  OK
ΔTL = = 0.19 in.
(L/d)TL = 126.00 / 0.19 = 663
 ΔTL = 0.19 in = L/663 < L/120   ➜  OK
fc⊥ = = 121.0 psi
 fc⊥ = 121.0 psi < Fc⊥x' = 625.00 psi  (CSI = 0.19)   ➜  OK
1/16/2021 6
