Species: Hem-Fir
Grade: HF No.2
Size: 4 x 8
Design Span (L): 6.00 ft.
Clear Span: 5.75 ft.
Total Span: 6.25 ft.
Live Load: 240 plf
Dead Load: 60 plf
Selfweight: 31.4 lbs
Dist. Selfweight: 5.24 plf
Total Weight: 32.8 lbs
Incised Lumber: Yes
Beam Design 2021A689
11/25/2021 1
G = 0.43
11/25/2021 2
= 29.74 lbs/ft3
Volumetotal = N[A x (L + lb)] = 1 x [25.38 x (72.00 + 3)] x (12 in./ft.)3 = 1.10 ft3
Volumespan = N[A x L] = 1 x [25.38 x 72.00] x (12 in./ft.)3 = 1.06 ft3
Total Weight (WT) = ρw x Volumetotal = 29.74 x 1.10 = 32.8 lbs
Self Weight (WS) = ρw x Volumespan = 29.74 x 1.06 = 31.4 lbs
Distributed Self Weight (ws) = = 5.24 plf
240 plf
60 plf
ws = 5.24 plf
5.75 ft.
6.25 ft.
953.88 lbs
953.88 lbs
11/25/2021 3
Fbx' = (850)(1.15)(1)(1)(1)(1.3)(0.8)(1) = 1016.6 psi
fb = = 537.6 psi
 fb = 537.6 psi < Fbx' = 1016.6 psi  (CSI = 0.53)   ➜  OK
11/25/2021 4
Fvx' = (150)(1.15)(1)(1)(0.8) = 138.00 psi
fv* = = 43.23 psi
 fv* = 43.23 psi < Fvx' = 138.00 psi  (CSI = 0.31)   ➜  OK
fv = = 54.13 psi
 fv = 54.13 psi < Fvx' = 138.00 psi  (CSI = 0.39)   ➜  OK
Ex' = Ex(CM)(Ct)(Ci) = 1300000(1)(1)(0.95) = 1235000 psi
11/25/2021 5
ΔLL = = 0.05 in.
(L/d)LL = 72.00 / 0.05 = 1412
 ΔLL = 0.05 in = L/1412 < L/360   ➜  OK
ΔTL = = 0.06 in.
(L/d)TL = 72.00 / 0.06 = 1110
 ΔTL = 0.06 in = L/1110 < L/240   ➜  OK
fc⊥ = = 90.8 psi
 fc⊥ = 90.8 psi < Fc⊥x' = 405.00 psi  (CSI = 0.22)   ➜  OK
11/25/2021 6
