Beam Design - Stairway Roof Beam
Size: 5.5 x 9
Design Span (L): 11.25 ft.
Clear Span: 11.00 ft.
Total Span: 11.50 ft.
Live Load: 300 plf
Dead Load: 200 plf
Selfweight: 130.6 lbs
Dist. Selfweight: 11.61 plf
Total Weight: 133.5 lbs
Beam Design Jason Dyke 305 SE Derby St 2021A687
11/24/2021 1
d = 9.000 in.
11/24/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [49.50 x (135.00 + 3)] x (12 in./ft.)3 = 3.95 ft3
Volumespan = N[A x L] = 1 x [49.50 x 135.00] x (12 in./ft.)3 = 3.87 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 3.95 = 133.5 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 3.87 = 130.6 lbs
Distributed Self Weight (ws) = = 11.61 plf
300 plf
200 plf
  ws = 11.61 plf
11.25 ft.
11.00 ft.
2941.73 lbs
2941.73 lbs
11/24/2021 3
lu/d = = 2.67
Rb = = 3.84
 Rb = 3.84 < 50   ➜  OK
11/24/2021 4
FbE = = 69343.31 psi
CL =   = 0.998
CL = 0.998 < CV = 1.0
Fbx' = (2400)(1.15)(1)(1)(0.998) = 2754.3 psi
fb = = 1308.1 psi
 fb = 1308.1 psi < Fbx' = 2754.3 psi  (CSI = 0.47)   ➜  OK
fv* = = 75.58 psi
11/24/2021 5
 fv* = 75.58 psi < Fvx' = 304.75 psi  (CSI = 0.25)   ➜  OK
fv = = 87.21 psi
 fv = 87.21 psi < Fvx' = 304.75 psi  (CSI = 0.29)   ➜  OK
ΔLL = = 0.18 in.
(L/d)LL = 135.00 / 0.18 = 751
 ΔLL = 0.18 in = L/751 < L/180   ➜  OK
ΔTL = = 0.31 in.
(L/d)TL = 135.00 / 0.31 = 440
 ΔTL = 0.31 in = L/440 < L/120   ➜  OK
11/24/2021 6
fc⊥ = = 178.3 psi
 fc⊥ = 178.3 psi < Fc⊥x' = 650.00 psi  (CSI = 0.27)   ➜  OK
11/24/2021 7
