Design Span (L): 11.25 ft.
Clear Span: 11.00 ft.
Total Span: 11.50 ft.
Selfweight: 111.2 lbs
Dist. Selfweight: 9.89 plf
Total Weight: 113.7 lbs
Beam Design 2021A685
11/23/2021 1
11/23/2021 2
Volumetotal = N[A x (L + lb)] = 3 x [13.88 x (135.00 + 3)] x (12 in./ft.)3 = 3.32 ft3
Volumespan = N[A x L] = 3 x [13.88 x 135.00] x (12 in./ft.)3 = 3.25 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 3.32 = 113.7 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 3.25 = 111.2 lbs
ws = 9.89 plf
11.25 ft.
11.00 ft.
1063.10 lbs
1063.10 lbs
11/23/2021 3
fb = = 547.0 psi
 fb = 547.0 psi < Fbx' = 1138.5 psi  (CSI = 0.48)   ➜  OK
11/23/2021 4
fv* = = 32.34 psi
 fv* = 32.34 psi < Fvx' = 207.00 psi  (CSI = 0.16)   ➜  OK
fv = = 37.48 psi
 fv = 37.48 psi < Fvx' = 207.00 psi  (CSI = 0.18)   ➜  OK
11/23/2021 5
ΔLL = = 0.08 in.
(L/d)LL = 135.00 / 0.08 = 1779
 ΔLL = 0.08 in = L/1779 < L/180   ➜  OK
ΔTL = = 0.14 in.
(L/d)TL = 135.00 / 0.14 = 962
 ΔTL = 0.14 in = L/962 < L/120   ➜  OK
fc⊥ = = 78.7 psi
 fc⊥ = 78.7 psi < Fc⊥x' = 625.00 psi  (CSI = 0.13)   ➜  OK
11/23/2021 6
