Size: 6.75 x 21
Design Span (L): 18.58 ft.
Clear Span: 18.25 ft.
Total Span: 18.92 ft.
Bearing (lb): 4 in.
Live Load: 90 plf
Dead Load: 15 plf
Selfweight: 617.6 lbs
Dist. Selfweight: 33.23 plf
Total Weight: 628.7 lbs
Lateral Support: 4' o/c
CV Volume Factor 0.931b - - - - -
Beam Design 2021A682
11/22/2021 1
b = 6.750 in.
d = 21.000 in.
A = 6.750 x 21.000 = 141.75 in.2
Sx = (6.750)(21.000)2/6 = 496.13 in.3
Sy = (6.750)2(21.000)/6 = 159.47 in.3
Ix = (6.750)(21.000)3/12 = 5209.31 in.4
Iy = (6.750)3(21.000)/12 = 538.21 in.4
11/22/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [141.75 x (223.00 + 4)] x (12 in./ft.)3 = 18.62 ft3
Volumespan = N[A x L] = 1 x [141.75 x 223.00] x (12 in./ft.)3 = 18.29 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 18.62 = 628.7 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 18.29 = 617.6 lbs
Distributed Self Weight (ws) = = 33.23 plf
90 plf
15 plf
  ws = 33.23 plf
18.58 ft.
18.25 ft.
18.92 ft.
1307.44 lbs
1307.44 lbs
11/22/2021 3
lu = Unbraced Length = 4 ft.
lu/d = = 2.29
Rb = = 6.75
 Rb = 6.75 < 50   ➜  OK
11/22/2021 4
FbE = = 22381.02 psi
CL =   = 0.993
CV = = 0.931
CV = 0.931 < CL = 0.993
Fbx' = (2400)(1.15)(1)(1)(0.931) = 2570.1 psi
fb = = 144.3 psi
 fb = 144.3 psi < Fbx' = 2570.1 psi  (CSI = 0.06)   ➜  OK
fv* = = 11.03 psi
11/22/2021 5
 fv* = 11.03 psi < Fvx' = 304.75 psi  (CSI = 0.04)   ➜  OK
fv = = 13.59 psi
 fv = 13.59 psi < Fvx' = 304.75 psi  (CSI = 0.04)   ➜  OK
ΔLL = = 0.03 in.
(L/d)LL = 223.00 / 0.03 = 8659
 ΔLL = 0.03 in = L/8659 < L/360   ➜  OK
ΔTL = = 0.04 in.
(L/d)TL = 223.00 / 0.04 = 5638
 ΔTL = 0.04 in = L/5638 < L/240   ➜  OK
11/22/2021 6
Ab = b x lb = 6.75 x 4 = 27.00 in2
fc⊥ = = 48.4 psi
 fc⊥ = 48.4 psi < Fc⊥x' = 650.00 psi  (CSI = 0.07)   ➜  OK
11/22/2021 7
