Size: 5.5 x 16.5
Design Span (L): 16.92 ft.
Clear Span: 16.46 ft.
Total Span: 17.38 ft.
Bearing (lb): 5.5 in.
Live Load: 0 plf
Dead Load: 25 plf
Selfweight: 360.0 lbs
Dist. Selfweight: 21.28 plf
Total Weight: 369.8 lbs
CL Beam Stability Factor 0.965 - - - - -
CV Volume Factor 0.983b - - - - -
Beam Design 2021A679
11/22/2021 1
d = 16.500 in.
11/22/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [90.75 x (203.06 + 5.5)] x (12 in./ft.)3 = 10.95 ft3
Volumespan = N[A x L] = 1 x [90.75 x 203.06] x (12 in./ft.)3 = 10.66 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 10.95 = 369.8 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 10.66 = 360.0 lbs
0 plf
25 plf
  ws = 21.28 plf
16.92 ft.
16.46 ft.
17.38 ft.
402.15 lbs
402.15 lbs
11/22/2021 3
lu = Unbraced Length = 16.922 ft.
lu/d = = 12.31
le = 1.63lu + 3d = 1.63(203.1) + 3(16.5) = 380.49 in. = 31.71 ft.  (NDS Table 3.3.3)
Rb = = 14.41
 Rb = 14.41 < 50   ➜  OK
11/22/2021 4
FbE = = 4914.66 psi
Fbx* = Fbx(CD)(CM)(Ct) = (2400)(0.9)(1)(1) = 2160.00 psi
CL =   = 0.965
CV = = 0.983
CL = 0.965 < CV = 0.983
Fbx' = (2400)(0.9)(1)(1)(0.965) = 2083.4 psi
fb = = 79.6 psi
 fb = 79.6 psi < Fbx' = 2083.4 psi  (CSI = 0.04)   ➜  OK
Fvx' = (265)(0.9)(1)(1) = 238.50 psi
fv* = = 5.42 psi
11/22/2021 5
 fv* = 5.42 psi < Fvx' = 238.50 psi  (CSI = 0.02)   ➜  OK
fv = = 6.47 psi
 fv = 6.47 psi < Fvx' = 238.50 psi  (CSI = 0.03)   ➜  OK
ΔLL = = 0.00 in.
(L/d)LL = 203.06 / 0.00 = ∞
ΔTL = = 0.02 in.
(L/d)TL = 203.06 / 0.02 = 8814
 ΔTL = 0.02 in = L/8814 < L/240   ➜  OK
11/22/2021 6
fc⊥ = = 13.3 psi
 fc⊥ = 13.3 psi < Fc⊥x' = 650.00 psi  (CSI = 0.02)   ➜  OK
11/22/2021 7
