Species: Alaska Yellow Cedar
Grade: AYC SS
Design Span (L): 19.75 ft.
Clear Span: 19.50 ft.
Total Span: 20.00 ft.
Live Load: 150 plf
Dead Load: 48 plf
Selfweight: 228.6 lbs
Dist. Selfweight: 11.58 plf
Total Weight: 231.5 lbs
Beam Design 2021A678
11/22/2021 1
AYC SS 1350 800 225 510 1200 1500000 550000 0.46
G = 0.46
11/22/2021 2
= 32.92 lbs/ft3
Volumetotal = N[A x (L + lb)] = 3 x [16.88 x (237.00 + 3)] x (12 in./ft.)3 = 7.03 ft3
Volumespan = N[A x L] = 3 x [16.88 x 237.00] x (12 in./ft.)3 = 6.94 ft3
Total Weight (WT) = ρw x Volumetotal = 32.92 x 7.03 = 231.5 lbs
Self Weight (WS) = ρw x Volumespan = 32.92 x 6.94 = 228.6 lbs
Distributed Self Weight (ws) = = 11.58 plf
150 plf
48 plf
ws = 11.58 plf
19.75 ft.
19.50 ft.
2095.75 lbs
2095.75 lbs
11/22/2021 3
Fbx' = (1350)(1.15)(0.85)(1)(1)(1)(1)(1) = 1319.6 psi
fb = = 1291.8 psi
 fb = 1291.8 psi < Fbx' = 1319.6 psi  (CSI = 0.98)   ➜  OK
11/22/2021 4
Fvx' = (225)(1.15)(0.97)(1)(1) = 250.99 psi
fv* = = 55.50 psi
 fv* = 55.50 psi < Fvx' = 250.99 psi  (CSI = 0.22)   ➜  OK
fv = = 61.32 psi
 fv = 61.32 psi < Fvx' = 250.99 psi  (CSI = 0.24)   ➜  OK
Ex' = Ex(CM)(Ct)(Ci) = 1500000(0.9)(1)(1) = 1350000 psi
11/22/2021 5
ΔLL = = 0.71 in.
(L/d)LL = 237.00 / 0.71 = 333
 ΔLL = 0.71 in = L/333 < L/240   ➜  OK
ΔTL = = 1.00 in.
(L/d)TL = 237.00 / 1.00 = 238
 ΔTL = 1.00 in = L/238 < L/180   ➜  OK
Fc⊥x' = (510)(0.67)(1)(1) = 341.70 psi
fc⊥ = = 155.2 psi
 fc⊥ = 155.2 psi < Fc⊥x' = 341.70 psi  (CSI = 0.45)   ➜  OK
11/22/2021 6
