Grade: SPF SS
Design Span (L): 19.75 ft.
Clear Span: 19.50 ft.
Total Span: 20.00 ft.
Live Load: 500 lbs
Dead Load: 0 lbs
Selfweight: 110.7 lbs
Dist. Selfweight: 5.61 plf
Total Weight: 112.1 lbs
Beam Design 2021A677
11/22/2021 1
11/22/2021 2
Volumetotal = N[A x (L + lb)] = 2 x [13.88 x (237.00 + 3)] x (12 in./ft.)3 = 3.85 ft3
Volumespan = N[A x L] = 2 x [13.88 x 237.00] x (12 in./ft.)3 = 3.81 ft3
Total Weight (WT) = ρw x Volumetotal = 29.10 x 3.85 = 112.1 lbs
Self Weight (WS) = ρw x Volumespan = 29.10 x 3.81 = 110.7 lbs
500 lbs
0 lbs
ws = 5.61 plf
19.75 ft.
19.50 ft.
306.07 lbs
306.07 lbs
11/22/2021 3
Fbx' = (1250)(1.00)(1)(1)(1)(1.1)(1)(1) = 1375.0 psi
fb = = 769.2 psi
 fb = 769.2 psi < Fbx' = 1375.0 psi  (CSI = 0.56)   ➜  OK
11/22/2021 4
fv* = = 16.27 psi
 fv* = 16.27 psi < Fvx' = 135.00 psi  (CSI = 0.12)   ➜  OK
fv = = 16.51 psi
 fv = 16.51 psi < Fvx' = 135.00 psi  (CSI = 0.12)   ➜  OK
11/22/2021 5
ΔLL =   =   = 0.47 in.
(L/d)LL = 237.00 / 0.47 = 507
 ΔLL = 0.47 in = L/507 < L/360   ➜  OK
ΔTL =   =   = 0.53 in.
(L/d)TL = 237.00 / 0.53 = 446
 ΔTL = 0.53 in = L/446 < L/240   ➜  OK
fc⊥ = = 34.0 psi
 fc⊥ = 34.0 psi < Fc⊥x' = 425.00 psi  (CSI = 0.08)   ➜  OK
11/22/2021 6
