Species: Hem-Fir
Grade: HF No.2
Size: 4 x 8
Design Span (L): 4.00 ft.
Clear Span: 3.75 ft.
Total Span: 4.25 ft.
Live Load: 623 plf
Dead Load: 273 plf
Selfweight: 21.0 lbs
Dist. Selfweight: 5.24 plf
Total Weight: 22.3 lbs
Incised Lumber: Yes
Beam Design 2021A676
11/22/2021 1
G = 0.43
11/22/2021 2
= 29.74 lbs/ft3
Volumetotal = N[A x (L + lb)] = 1 x [25.38 x (48.00 + 3)] x (12 in./ft.)3 = 0.75 ft3
Volumespan = N[A x L] = 1 x [25.38 x 48.00] x (12 in./ft.)3 = 0.70 ft3
Total Weight (WT) = ρw x Volumetotal = 29.74 x 0.75 = 22.3 lbs
Self Weight (WS) = ρw x Volumespan = 29.74 x 0.70 = 21.0 lbs
Distributed Self Weight (ws) = = 5.24 plf
623 plf
273 plf
ws = 5.24 plf
4.00 ft.
3.75 ft.
4.25 ft.
1915.14 lbs
1915.14 lbs
11/22/2021 3
Fbx' = (850)(1.15)(1)(1)(1)(1.3)(0.8)(1) = 1016.6 psi
fb = = 705.4 psi
 fb = 705.4 psi < Fbx' = 1016.6 psi  (CSI = 0.69)   ➜  OK
11/22/2021 4
Fvx' = (150)(1.15)(1)(1)(0.8) = 138.00 psi
fv* = = 74.36 psi
 fv* = 74.36 psi < Fvx' = 138.00 psi  (CSI = 0.54)   ➜  OK
fv = = 106.55 psi
 fv = 106.55 psi < Fvx' = 138.00 psi  (CSI = 0.77)   ➜  OK
Ex' = Ex(CM)(Ct)(Ci) = 1300000(1)(1)(0.95) = 1235000 psi
11/22/2021 5
ΔLL = = 0.03 in.
(L/d)LL = 48.00 / 0.03 = 1836
 ΔLL = 0.03 in = L/1836 < L/360   ➜  OK
ΔTL = = 0.04 in.
(L/d)TL = 48.00 / 0.04 = 1269
 ΔTL = 0.04 in = L/1269 < L/240   ➜  OK
fc⊥ = = 182.4 psi
 fc⊥ = 182.4 psi < Fc⊥x' = 405.00 psi  (CSI = 0.45)   ➜  OK
11/22/2021 6
