Size: 4 x 6
Design Span (L): 16.83 ft.
Clear Span: 16.67 ft.
Total Span: 17.00 ft.
Bearing (lb): 2 in.
Live Load: 75 plf
Dead Load: 25 plf
Selfweight: 86.8 lbs
Dist. Selfweight: 5.16 plf
Total Weight: 87.7 lbs
Beam Design 2021A675
11/22/2021 1
11/22/2021 2
= 38.58 lbs/ft3
Volumetotal = N[A x (L + lb)] = 1 x [19.25 x (202.00 + 2)] x (12 in./ft.)3 = 2.27 ft3
Volumespan = N[A x L] = 1 x [19.25 x 202.00] x (12 in./ft.)3 = 2.25 ft3
Total Weight (WT) = ρw x Volumetotal = 38.58 x 2.27 = 87.7 lbs
Self Weight (WS) = ρw x Volumespan = 38.58 x 2.25 = 86.8 lbs
Distributed Self Weight (ws) = = 5.16 plf
25 plf
ws = 5.16 plf
16.83 ft.
16.67 ft.
17.00 ft.
893.82 lbs
893.82 lbs
11/22/2021 3
fb = = 2532.9 psi
 fb = 2532.9 psi > Fbx' = 1150.0 psi  (CSI = 2.20)   ➜  NG
11/22/2021 4
fv* = = 65.21 psi
 fv* = 65.21 psi < Fvx' = 195.21 psi  (CSI = 0.33)   ➜  OK
fv = = 68.97 psi
 fv = 68.97 psi < Fvx' = 195.21 psi  (CSI = 0.35)   ➜  OK
11/22/2021 5
ΔLL = = 2.22 in.
(L/d)LL = 202.00 / 2.22 = 91
 ΔLL = 2.22 in = L/91 > L/360   ➜  NG
ΔTL = = 3.11 in.
(L/d)TL = 202.00 / 3.11 = 65
 ΔTL = 3.11 in = L/65 > L/240   ➜  NG
Ab = b x lb = 3.5 x 2 = 7.00 in2
fc⊥ = = 127.7 psi
 fc⊥ = 127.7 psi < Fc⊥x' = 378.55 psi  (CSI = 0.34)   ➜  OK
11/22/2021 6
