Species: Hem-Fir
Grade: HF SS
Size: 4 x 8
Design Span (L): 3.75 ft.
Clear Span: 3.50 ft.
Total Span: 4.00 ft.
Live Load: 426 plf
Dead Load: 250 plf
Selfweight: 19.7 lbs
Dist. Selfweight: 5.24 plf
Total Weight: 21.0 lbs
Incised Lumber: Yes
Beam Design 2021A670
11/21/2021 1
G = 0.43
11/21/2021 2
= 29.74 lbs/ft3
Volumetotal = N[A x (L + lb)] = 1 x [25.38 x (45.00 + 3)] x (12 in./ft.)3 = 0.70 ft3
Volumespan = N[A x L] = 1 x [25.38 x 45.00] x (12 in./ft.)3 = 0.66 ft3
Total Weight (WT) = ρw x Volumetotal = 29.74 x 0.70 = 21.0 lbs
Self Weight (WS) = ρw x Volumespan = 29.74 x 0.66 = 19.7 lbs
Distributed Self Weight (ws) = = 5.24 plf
426 plf
250 plf
ws = 5.24 plf
3.75 ft.
3.50 ft.
4.00 ft.
1362.48 lbs
1362.48 lbs
11/21/2021 3
Fbx' = (1400)(1.15)(1)(1)(1)(1.3)(0.8)(1) = 1674.4 psi
fb = = 468.7 psi
 fb = 468.7 psi < Fbx' = 1674.4 psi  (CSI = 0.28)   ➜  OK
11/21/2021 4
Fvx' = (150)(1.15)(1)(1)(0.8) = 138.00 psi
fv* = = 51.18 psi
 fv* = 51.18 psi < Fvx' = 138.00 psi  (CSI = 0.37)   ➜  OK
fv = = 75.51 psi
 fv = 75.51 psi < Fvx' = 138.00 psi  (CSI = 0.55)   ➜  OK
11/21/2021 5
ΔLL = = 0.01 in.
(L/d)LL = 45.00 / 0.01 = 4011
 ΔLL = 0.01 in = L/4011 < L/240   ➜  OK
ΔTL = = 0.02 in.
(L/d)TL = 45.00 / 0.02 = 2508
 ΔTL = 0.02 in = L/2508 < L/180   ➜  OK
fc⊥ = = 129.8 psi
 fc⊥ = 129.8 psi < Fc⊥x' = 405.00 psi  (CSI = 0.32)   ➜  OK
11/21/2021 6
