Beam Design - WOOD LAGGING
Grade: SP SS
Design Span (L): 4.75 ft.
Clear Span: 4.50 ft.
Total Span: 5.00 ft.
Live Load: 0 plf
Dead Load: 240 plf
Selfweight: 35.3 lbs
Dist. Selfweight: 7.44 plf
Total Weight: 37.2 lbs
Orientation: Horizontal
Notes: SUPPORT OF EXCAVATION WOOD LAGGING DESIGN
Beam Design KONSTRUCT ENGINEERING 74 TEN EYCK STREET, BROOKLYN 74 TEN EYCK ST
11/18/2021 1
SP SS 1700 1150 175 565 1650 1800000 660000 0.55
11/18/2021 2
= 38.58 lbs/ft3
Volumetotal = N[A x (L + lb)] = 2 x [13.88 x (57.00 + 3)] x (12 in./ft.)3 = 0.96 ft3
Volumespan = N[A x L] = 2 x [13.88 x 57.00] x (12 in./ft.)3 = 0.92 ft3
Total Weight (WT) = ρw x Volumetotal = 38.58 x 0.96 = 37.2 lbs
Self Weight (WS) = ρw x Volumespan = 38.58 x 0.92 = 35.3 lbs
Distributed Self Weight (ws) = = 7.44 plf
0 plf
240 plf
ws = 7.44 plf
4.75 ft.
4.50 ft.
5.00 ft.
618.59 lbs
618.59 lbs
11/18/2021 3
Fby' = (1700)(0.9)(0.85)(1)(1)(1)(1.2)(1)(1.15) = 1794.7 psi
fb = = 1207.1 psi
 fb = 1207.1 psi < Fby' = 1794.7 psi  (CSI = 0.67)   ➜  OK
11/18/2021 4
Fvy' = (175)(0.9)(0.97)(1)(1) = 152.78 psi
fv* = = 30.09 psi
 fv* = 30.09 psi < Fvy' = 152.78 psi  (CSI = 0.20)   ➜  OK
fv = = 31.77 psi
 fv = 31.77 psi < Fvy' = 152.78 psi  (CSI = 0.21)   ➜  OK
Ey' = Ey(CM)(Ct)(Ci) = 1800000(0.9)(1)(1) = 1620000 psi
11/18/2021 5
ΔLL = = 0.00 in.
(L/d)LL = 57.00 / 0.00 = ∞
ΔTL = = 0.34 in.
(L/d)TL = 57.00 / 0.34 = 170
 ΔTL = 0.34 in = L/170 < L/120   ➜  OK
Fc⊥y' = (565)(0.67)(1)(1) = 378.55 psi
Ab = d x lb = 9.25 x 3 = 27.75 in2
fc⊥ = = 11.1 psi
 fc⊥ = 11.1 psi < Fc⊥y' = 378.55 psi  (CSI = 0.03)   ➜  OK
11/18/2021 6
