Beam Design - WOOD LAGGING
Grade: SP DSS
Size: 4 x 10
Design Span (L): 5.75 ft.
Clear Span: 5.50 ft.
Total Span: 6.00 ft.
Live Load: 0 plf
Dead Load: 779 plf
Selfweight: 49.9 lbs
Dist. Selfweight: 8.67 plf
Total Weight: 52.0 lbs
Orientation: Horizontal
Notes: SUPPORT OF EXCAVATION WOOD LAGGING DESIGN
CF Size Factor 1.1 1 - 1 - -
Beam Design KONSTRUCT ENGINEERING 74 TEN EYCK STREET, BROOKLYN 74 TEN EYCK ST
11/18/2021 1
11/18/2021 2
= 38.58 lbs/ft3
Volumetotal = N[A x (L + lb)] = 1 x [32.38 x (69.00 + 3)] x (12 in./ft.)3 = 1.35 ft3
Volumespan = N[A x L] = 1 x [32.38 x 69.00] x (12 in./ft.)3 = 1.29 ft3
Total Weight (WT) = ρw x Volumetotal = 38.58 x 1.35 = 52.0 lbs
Self Weight (WS) = ρw x Volumespan = 38.58 x 1.29 = 49.9 lbs
Distributed Self Weight (ws) = = 8.67 plf
0 plf
779 plf
ws = 8.67 plf
5.75 ft.
5.50 ft.
2363.02 lbs
2363.02 lbs
11/18/2021 3
Fby' = (1950)(0.9)(0.85)(1)(1)(1.1)(1.1)(1)(1.15) = 2075.8 psi
fb = = 2068.5 psi
 fb = 2068.5 psi < Fby' = 2075.8 psi  (CSI = 1.00)   ➜  OK
11/18/2021 4
Fvy' = (175)(0.9)(0.97)(1)(1) = 152.78 psi
fv* = = 94.28 psi
 fv* = 94.28 psi < Fvy' = 152.78 psi  (CSI = 0.62)   ➜  OK
fv = = 104.92 psi
 fv = 104.92 psi < Fvy' = 152.78 psi  (CSI = 0.69)   ➜  OK
Ey' = Ey(CM)(Ct)(Ci) = 1900000(0.9)(1)(1) = 1710000 psi
11/18/2021 5
ΔLL = = 0.00 in.
(L/d)LL = 69.00 / 0.00 = ∞
 ΔLL = 0.00 in = L/∞ < L/240   ➜  OK
ΔTL = = 0.34 in.
(L/d)TL = 69.00 / 0.34 = 201
 ΔTL = 0.34 in = L/201 < L/180   ➜  OK
Fc⊥y' = (660)(0.67)(1)(1) = 442.20 psi
Ab = d x lb = 9.25 x 3 = 27.75 in2
fc⊥ = = 85.2 psi
 fc⊥ = 85.2 psi < Fc⊥y' = 442.20 psi  (CSI = 0.19)   ➜  OK
11/18/2021 6
