Beam Design - WOOD LAGGING
Grade: SP SS
Size: 4 x 10
Design Span (L): 4.92 ft.
Clear Span: 4.58 ft.
Total Span: 5.25 ft.
Bearing (lb): 4 in.
Live Load: 0 plf
Dead Load: 360 plf
Selfweight: 42.7 lbs
Dist. Selfweight: 8.67 plf
Total Weight: 45.5 lbs
Defl. Limits: 480|360
Orientation: Horizontal
Notes: SUPPORT OF EXCAVATION WOOD LAGGING DESIGN
CF Size Factor 1.1 1 - 1 - -
Beam Design KONSTRUCT ENGINEERING 74 TEN EYCK STREET, BROOKLYN 74 TEN EYCK ST
11/18/2021 1
SP SS 1700 1150 175 565 1650 1800000 660000 0.55
11/18/2021 2
= 38.58 lbs/ft3
Volumetotal = N[A x (L + lb)] = 1 x [32.38 x (59.00 + 4)] x (12 in./ft.)3 = 1.18 ft3
Volumespan = N[A x L] = 1 x [32.38 x 59.00] x (12 in./ft.)3 = 1.11 ft3
Total Weight (WT) = ρw x Volumetotal = 38.58 x 1.18 = 45.5 lbs
Self Weight (WS) = ρw x Volumespan = 38.58 x 1.11 = 42.7 lbs
Distributed Self Weight (ws) = = 8.67 plf
0 plf
360 plf
ws = 8.67 plf
4.92 ft.
4.58 ft.
5.25 ft.
967.83 lbs
967.83 lbs
11/18/2021 3
Fby' = (1700)(0.9)(0.85)(1)(1)(1.1)(1.1)(1)(1.15) = 1809.6 psi
fb = = 708.0 psi
 fb = 708.0 psi < Fby' = 1809.6 psi  (CSI = 0.39)   ➜  OK
11/18/2021 4
Fvy' = (175)(0.9)(0.97)(1)(1) = 152.78 psi
fv* = = 37.01 psi
 fv* = 37.01 psi < Fvy' = 152.78 psi  (CSI = 0.24)   ➜  OK
fv = = 41.99 psi
 fv = 41.99 psi < Fvy' = 152.78 psi  (CSI = 0.27)   ➜  OK
LL Allowable: L/480
TL Allowable: L/360
Ey' = Ey(CM)(Ct)(Ci) = 1800000(0.9)(1)(1) = 1620000 psi
11/18/2021 5
ΔLL = = 0.00 in.
(L/d)LL = 59.00 / 0.00 = ∞
 ΔLL = 0.00 in = L/∞ < L/480   ➜  OK
ΔTL = = 0.09 in.
(L/d)TL = 59.00 / 0.09 = 652
 ΔTL = 0.09 in = L/652 < L/360   ➜  OK
Fc⊥y' = (565)(0.67)(1)(1) = 378.55 psi
Ab = d x lb = 9.25 x 4 = 37.00 in2
fc⊥ = = 26.2 psi
 fc⊥ = 26.2 psi < Fc⊥y' = 378.55 psi  (CSI = 0.07)   ➜  OK
11/18/2021 6
