Grade: DF SS
Design Span (L): 16.25 ft.
Clear Span: 16.00 ft.
Total Span: 16.50 ft.
Live Load: 50 plf
Dead Load: 100 plf
Selfweight: 130.3 lbs
Dist. Selfweight: 8.02 plf
Total Weight: 132.3 lbs
Beam Design Groepper
11/17/2021 1
11/17/2021 2
Volumetotal = N[A x (L + lb)] = 2 x [16.88 x (195.00 + 3)] x (12 in./ft.)3 = 3.87 ft3
Volumespan = N[A x L] = 2 x [16.88 x 195.00] x (12 in./ft.)3 = 3.81 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 3.87 = 132.3 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 3.81 = 130.3 lbs
50 plf
ws = 8.02 plf
16.25 ft.
16.50 ft.
1303.64 lbs
1303.64 lbs
11/17/2021 3
Fbx' = (1500)(1.15)(1)(1)(1)(1)(1)(1) = 1725.0 psi
fb = = 989.1 psi
 fb = 989.1 psi < Fbx' = 1725.0 psi  (CSI = 0.57)   ➜  OK
11/17/2021 4
fv* = = 50.48 psi
 fv* = 50.48 psi < Fvx' = 207.00 psi  (CSI = 0.24)   ➜  OK
fv = = 57.06 psi
 fv = 57.06 psi < Fvx' = 207.00 psi  (CSI = 0.28)   ➜  OK
11/17/2021 5
ΔLL = = 0.12 in.
(L/d)LL = 195.00 / 0.12 = 1681
 ΔLL = 0.12 in = L/1681 < L/360   ➜  OK
ΔTL = = 0.37 in.
(L/d)TL = 195.00 / 0.37 = 532
 ΔTL = 0.37 in = L/532 < L/240   ➜  OK
fc⊥ = = 144.8 psi
 fc⊥ = 144.8 psi < Fc⊥x' = 625.00 psi  (CSI = 0.23)   ➜  OK
11/17/2021 6
