Design Span (L): 15.33 ft.
Clear Span: 15.08 ft.
Total Span: 15.58 ft.
Live Load: 50 plf
Dead Load: 100 plf
Selfweight: 134.1 lbs
Dist. Selfweight: 8.75 plf
Total Weight: 136.3 lbs
CL Beam Stability Factor 0.942 - - - - -
Beam Design 2021A662
11/16/2021 1
11/16/2021 2
Volumetotal = N[A x (L + lb)] = 2 x [16.88 x (183.96 + 3)] x (12 in./ft.)3 = 3.65 ft3
Volumespan = N[A x L] = 2 x [16.88 x 183.96] x (12 in./ft.)3 = 3.59 ft3
Total Weight (WT) = ρw x Volumetotal = 37.33 x 3.65 = 136.3 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 3.59 = 134.1 lbs
50 plf
ws = 8.75 plf
15.33 ft.
15.08 ft.
15.58 ft.
1236.66 lbs
1236.66 lbs
11/16/2021 3
lu = Unbraced Length = 15.330 ft.
lu/d = = 16.35
le = 1.63lu + 3d = 1.63(184.0) + 3(11.25) = 333.60 in. = 27.80 ft.  (NDS Table 3.3.3)
Rb = = 20.42
 Rb = 20.42 < 50   ➜  OK
11/16/2021 4
FbE = = 1467.60 psi
Fbx* = Fbx(CD)(CM)(Ct)(CF)(Ci)(Cr) = (750)(1.15)(1)(1)(1)(1)(1) = 862.50 psi
CL =   = 0.942
Fbx' = (750)(1.15)(1)(1)(0.942)(1)(1)(1) = 812.2 psi
fb = = 884.3 psi
 fb = 884.3 psi > Fbx' = 812.2 psi  (CSI = 1.09)   ➜  NG
fv* = = 47.47 psi
 fv* = 47.47 psi < Fvx' = 201.25 psi  (CSI = 0.24)   ➜  OK
fv = = 54.08 psi
 fv = 54.08 psi < Fvx' = 201.25 psi  (CSI = 0.27)   ➜  OK
11/16/2021 5
ΔLL = = 0.12 in.
(L/d)LL = 183.96 / 0.12 = 1475
 ΔLL = 0.12 in = L/1475 < L/360   ➜  OK
ΔTL = = 0.40 in.
(L/d)TL = 183.96 / 0.40 = 465
 ΔTL = 0.40 in = L/465 < L/240   ➜  OK
fc⊥ = = 137.4 psi
 fc⊥ = 137.4 psi < Fc⊥x' = 565.00 psi  (CSI = 0.24)   ➜  OK
11/16/2021 6
