Beam Design - RB
Size: 5.125 x 16.5
Design Span (L): 15.63 ft.
Clear Span: 15.25 ft.
Total Span: 16.00 ft.
Bearing (lb): 4.5 in.
Live Load: 1280 plf
Dead Load: 160 plf
Selfweight: 309.8 lbs
Dist. Selfweight: 19.83 plf
Total Weight: 317.2 lbs
CV Volume Factor 0.998b - - - - -
Beam Design 2021A661
11/12/2021 1
b = 5.125 in.
d = 16.500 in.
A = 5.125 x 16.500 = 84.56 in.2
Sx = (5.125)(16.500)2/6 = 232.55 in.3
Sy = (5.125)2(16.500)/6 = 72.23 in.3
Ix = (5.125)(16.500)3/12 = 1918.51 in.4
Iy = (5.125)3(16.500)/12 = 185.09 in.4
11/12/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [84.56 x (187.50 + 4.5)] x (12 in./ft.)3 = 9.40 ft3
Volumespan = N[A x L] = 1 x [84.56 x 187.50] x (12 in./ft.)3 = 9.18 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 9.40 = 317.2 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 9.18 = 309.8 lbs
Distributed Self Weight (ws) = = 19.83 plf
1280 plf
160 plf
  ws = 19.83 plf
15.63 ft.
15.25 ft.
11678.61 lbs
11678.61 lbs
11/12/2021 3
CV = = 0.998
CV = 0.998 < CL = 1
Fbx' = (2400)(1.15)(1)(1)(0.998) = 2753.7 psi
fb = = 2298.9 psi
 fb = 2298.9 psi < Fbx' = 2753.7 psi  (CSI = 0.83)   ➜  OK
11/12/2021 4
fv* = = 166.70 psi
 fv* = 166.70 psi < Fvx' = 304.75 psi  (CSI = 0.55)   ➜  OK
fv = = 202.30 psi
 fv = 202.30 psi < Fvx' = 304.75 psi  (CSI = 0.66)   ➜  OK
11/12/2021 5
ΔLL = = 0.50 in.
(L/d)LL = 187.50 / 0.50 = 377
 ΔLL = 0.50 in = L/377 < L/360   ➜  OK
ΔTL = = 0.57 in.
(L/d)TL = 187.50 / 0.57 = 331
 ΔTL = 0.57 in = L/331 < L/240   ➜  OK
Ab = b x lb = 5.125 x 4.5 = 23.06 in2
fc⊥ = = 506.4 psi
 fc⊥ = 506.4 psi < Fc⊥x' = 650.00 psi  (CSI = 0.78)   ➜  OK
11/12/2021 6
