Beam Design - CEILING-ATTIC
Grade: SPF No.2
Design Span (L): 15.75 ft.
Clear Span: 15.50 ft.
Total Span: 16.00 ft.
Live Load: 27 plf
Dead Load: 13.33 plf
Selfweight: 44.2 lbs
Dist. Selfweight: 2.80 plf
Total Weight: 44.9 lbs
Beam Design OCKRIN
11/12/2021 1
Beam Design OCKRIN
11/12/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [13.88 x (189.00 + 3)] x (12 in./ft.)3 = 1.54 ft3
Volumespan = N[A x L] = 1 x [13.88 x 189.00] x (12 in./ft.)3 = 1.52 ft3
Total Weight (WT) = ρw x Volumetotal = 29.10 x 1.54 = 44.9 lbs
Self Weight (WS) = ρw x Volumespan = 29.10 x 1.52 = 44.2 lbs
Distributed Self Weight (ws) = = 2.80 plf
27 plf
13.33 plf
ws = 2.80 plf
15.75 ft.
15.50 ft.
345.07 lbs
345.07 lbs
Beam Design OCKRIN
11/12/2021 3
Fbx' = (875)(1.00)(1)(1)(1)(1.1)(1)(1.15) = 1106.9 psi
fb = = 750.3 psi
 fb = 750.3 psi < Fbx' = 1106.9 psi  (CSI = 0.68)   ➜  OK
Beam Design OCKRIN
11/12/2021 4
fv* = = 33.13 psi
 fv* = 33.13 psi < Fvx' = 135.00 psi  (CSI = 0.25)   ➜  OK
fv = = 36.72 psi
 fv = 36.72 psi < Fvx' = 135.00 psi  (CSI = 0.27)   ➜  OK
Beam Design OCKRIN
11/12/2021 5
ΔLL = = 0.27 in.
(L/d)LL = 189.00 / 0.27 = 700
 ΔLL = 0.27 in = L/700 < L/360   ➜  OK
ΔTL = = 0.43 in.
(L/d)TL = 189.00 / 0.43 = 438
 ΔTL = 0.43 in = L/438 < L/240   ➜  OK
fc⊥ = = 76.7 psi
 fc⊥ = 76.7 psi < Fc⊥x' = 425.00 psi  (CSI = 0.18)   ➜  OK
Beam Design OCKRIN
11/12/2021 6
