Grade: DF SS
Design Span (L): 18.25 ft.
Clear Span: 18.00 ft.
Total Span: 18.50 ft.
Live Load: 3010 lbs
Dead Load: 860 lbs
Selfweight: 146.3 lbs
Dist. Selfweight: 8.02 plf
Total Weight: 148.3 lbs
Lateral Support: 4' o/c
Beam Design Groepper
11/12/2021 1
11/12/2021 2
Volumetotal = N[A x (L + lb)] = 2 x [16.88 x (219.00 + 3)] x (12 in./ft.)3 = 4.34 ft3
Volumespan = N[A x L] = 2 x [16.88 x 219.00] x (12 in./ft.)3 = 4.28 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 4.34 = 148.3 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 4.28 = 146.3 lbs
3010 lbs
860 lbs
ws = 8.02 plf
18.25 ft.
18.00 ft.
18.50 ft.
2009.15 lbs
2009.15 lbs
11/12/2021 3
lu = Unbraced Length = 4 ft.
lu/d = = 4.27
Rb = = 11.12
 Rb = 11.12 < 50   ➜  OK
11/12/2021 4
FbE = = 6699.03 psi
Fbx* = Fbx(CD)(CM)(Ct)(CF)(Ci)(Cr) = (1500)(1.15)(1)(1)(1)(1)(1) = 1725.00 psi
CL =   = 0.983
Fbx' = (1500)(1.15)(1)(1)(0.983)(1)(1)(1) = 1696.2 psi
fb = = 3411.6 psi
 fb = 3411.6 psi > Fbx' = 1696.2 psi  (CSI = 2.01)   ➜  NG
fv* = = 88.92 psi
 fv* = 88.92 psi < Fvx' = 207.00 psi  (CSI = 0.43)   ➜  OK
fv = = 89.25 psi
 fv = 89.25 psi < Fvx' = 207.00 psi  (CSI = 0.43)   ➜  OK
11/12/2021 5
ΔLL =   =   = 0.97 in.
(L/d)LL = 219.00 / 0.97 = 225
 ΔLL = 0.97 in = L/225 > L/360   ➜  NG
ΔTL =   =   = 1.28 in.
(L/d)TL = 219.00 / 1.28 = 171
 ΔTL = 1.28 in = L/171 > L/240   ➜  NG
fc⊥ = = 223.2 psi
 fc⊥ = 223.2 psi < Fc⊥x' = 625.00 psi  (CSI = 0.36)   ➜  OK
11/12/2021 6
