Grade: DF SS
Design Span (L): 18.50 ft.
Clear Span: 18.25 ft.
Total Span: 18.75 ft.
Live Load: 168 lbs
Dead Load: 48 lbs
Selfweight: 148.3 lbs
Dist. Selfweight: 8.02 plf
Total Weight: 150.3 lbs
Lateral Support: 4' o/c
Beam Design Groepper
11/12/2021 1
11/12/2021 2
Volumetotal = N[A x (L + lb)] = 2 x [16.88 x (222.00 + 3)] x (12 in./ft.)3 = 4.39 ft3
Volumespan = N[A x L] = 2 x [16.88 x 222.00] x (12 in./ft.)3 = 4.34 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 4.39 = 150.3 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 4.34 = 148.3 lbs
168 lbs
48 lbs
ws = 8.02 plf
18.50 ft.
18.25 ft.
18.75 ft.
183.15 lbs
183.15 lbs
11/12/2021 3
lu = Unbraced Length = 4 ft.
lu/d = = 4.27
Rb = = 11.12
 Rb = 11.12 < 50   ➜  OK
11/12/2021 4
FbE = = 6699.03 psi
Fbx* = Fbx(CD)(CM)(Ct)(CF)(Ci)(Cr) = (1500)(1.15)(1)(1)(1)(1)(1) = 1725.00 psi
CL =   = 0.983
Fbx' = (1500)(1.15)(1)(1)(0.983)(1)(1)(1) = 1696.2 psi
fb = = 254.5 psi
 fb = 254.5 psi < Fbx' = 1696.2 psi  (CSI = 0.15)   ➜  OK
fv* = = 7.76 psi
 fv* = 7.76 psi < Fvx' = 207.00 psi  (CSI = 0.04)   ➜  OK
fv = = 8.10 psi
 fv = 8.10 psi < Fvx' = 207.00 psi  (CSI = 0.04)   ➜  OK
11/12/2021 5
ΔLL =   =   = 0.06 in.
(L/d)LL = 222.00 / 0.06 = 3921
 ΔLL = 0.06 in = L/3921 < L/360   ➜  OK
ΔTL =   =   = 0.10 in.
(L/d)TL = 222.00 / 0.10 = 2134
 ΔTL = 0.10 in = L/2134 < L/240   ➜  OK
fc⊥ = = 20.4 psi
 fc⊥ = 20.4 psi < Fc⊥x' = 625.00 psi  (CSI = 0.03)   ➜  OK
11/12/2021 6
