Size: 3.5 x 7.5
Design Span (L): 11.71 ft.
Clear Span: 11.42 ft.
Bearing (lb): 3.5 in.
Selfweight: 72.1 lbs
Dist. Selfweight: 6.15 plf
Total Weight: 73.9 lbs
Beam Design 2021A655
11/11/2021 1
d = 7.500 in.
A = 3.500 x 7.500 = 26.25 in.2
Sx = (3.500)(7.500)2/6 = 32.81 in.3
Sy = (3.500)2(7.500)/6 = 15.31 in.3
Ix = (3.500)(7.500)3/12 = 123.05 in.4
Iy = (3.500)3(7.500)/12 = 26.80 in.4
11/11/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [26.25 x (140.50 + 3.5)] x (12 in./ft.)3 = 2.19 ft3
Volumespan = N[A x L] = 1 x [26.25 x 140.50] x (12 in./ft.)3 = 2.13 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 2.19 = 73.9 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 2.13 = 72.1 lbs
Distributed Self Weight (ws) = = 6.15 plf
  ws = 6.15 plf
11.71 ft.
11.42 ft.
1086.90 lbs
1086.90 lbs
11/11/2021 3
fb = = 1135.2 psi
 fb = 1135.2 psi < Fbx' = 2760.0 psi  (CSI = 0.41)   ➜  OK
11/11/2021 4
fv* = = 54.13 psi
 fv* = 54.13 psi < Fvx' = 304.75 psi  (CSI = 0.18)   ➜  OK
fv = = 60.60 psi
 fv = 60.60 psi < Fvx' = 304.75 psi  (CSI = 0.20)   ➜  OK
11/11/2021 5
ΔLL = = 0.19 in.
(L/d)LL = 140.50 / 0.19 = 736
 ΔLL = 0.19 in = L/736 < L/360   ➜  OK
ΔTL = = 0.35 in.
(L/d)TL = 140.50 / 0.35 = 406
 ΔTL = 0.35 in = L/406 < L/240   ➜  OK
fc⊥ = = 88.7 psi
 fc⊥ = 88.7 psi < Fc⊥x' = 650.00 psi  (CSI = 0.14)   ➜  OK
11/11/2021 6
