Grade: 24F-V3 1.8E SP/SP
Size: 3.5 x 12.375
Design Span (L): 12.75 ft.
Clear Span: 12.50 ft.
Total Span: 13.00 ft.
Live Load: 600 plf
Dead Load: 300 plf
Selfweight: 141.5 lbs
Dist. Selfweight: 11.10 plf
Total Weight: 144.2 lbs
Load Duration: 1.33
CL Beam Stability Factor 0.854 - - - - -
Beam Design Roberts Home left upper beam
11/10/2021 1
d = 12.375 in.
A = 3.500 x 12.375 = 43.31 in.2
Sx = (3.500)(12.375)2/6 = 89.33 in.3
Sy = (3.500)2(12.375)/6 = 25.27 in.3
Ix = (3.500)(12.375)3/12 = 552.74 in.4
Iy = (3.500)3(12.375)/12 = 44.21 in.4
11/10/2021 2
= 36.89 lbs/ft3
Volumetotal = N[A x (L + lb)] = 1 x [43.31 x (153.00 + 3)] x (12 in./ft.)3 = 3.91 ft3
Volumespan = N[A x L] = 1 x [43.31 x 153.00] x (12 in./ft.)3 = 3.83 ft3
Total Weight (WT) = ρw x Volumetotal = 36.89 x 3.91 = 144.2 lbs
Self Weight (WS) = ρw x Volumespan = 36.89 x 3.83 = 141.5 lbs
Distributed Self Weight (ws) = = 11.10 plf
600 plf
300 plf
  ws = 11.10 plf
12.75 ft.
12.50 ft.
13.00 ft.
5922.12 lbs
5922.12 lbs
11/10/2021 3
lu = Unbraced Length = 12.750 ft.
lu/d = = 12.36
le = 1.63lu + 3d = 1.63(153.0) + 3(12.375) = 286.51 in. = 23.88 ft.  (NDS Table 3.3.3)
Rb = = 17.01
 Rb = 17.01 < 50   ➜  OK
11/10/2021 4
FbE = = 3524.06 psi
Fbx* = Fbx(CD)(CM)(Ct) = (2400)(1.33)(1)(1) = 3192.00 psi
CL =   = 0.854
CL = 0.854 < CV = 1.0
Fbx' = (2400)(1.33)(1)(1)(0.854) = 2726.2 psi
fb = = 2487.0 psi
 fb = 2487.0 psi < Fbx' = 2726.2 psi  (CSI = 0.91)   ➜  OK
Fvx' = (300)(1.33)(1)(1) = 399.00 psi
fv* = = 168.61 psi
11/10/2021 5
 fv* = 168.61 psi < Fvx' = 399.00 psi  (CSI = 0.42)   ➜  OK
fv = = 201.15 psi
 fv = 201.15 psi < Fvx' = 399.00 psi  (CSI = 0.50)   ➜  OK
ΔLL = = 0.36 in.
(L/d)LL = 153.00 / 0.36 = 427
 ΔLL = 0.36 in = L/427 < L/360   ➜  OK
ΔTL = = 0.54 in.
(L/d)TL = 153.00 / 0.54 = 281
 ΔTL = 0.54 in = L/281 < L/240   ➜  OK
11/10/2021 6
fc⊥ = = 564.0 psi
 fc⊥ = 564.0 psi < Fc⊥x' = 740.00 psi  (CSI = 0.76)   ➜  OK
11/10/2021 7
