Beam Design - OPEN AREA BEAM
Grade: SPF SS
Design Span (L): 10.75 ft.
Clear Span: 10.50 ft.
Total Span: 11.00 ft.
Quantity (N): 4
Live Load: 640 plf
Dead Load: 160 plf
Selfweight: 146.6 lbs
Dist. Selfweight: 13.64 plf
Total Weight: 150.0 lbs
Beam Design OCKRIN
11/9/2021 1
Beam Design OCKRIN
11/9/2021 2
Volumetotal = N[A x (L + lb)] = 4 x [16.88 x (129.00 + 3)] x (12 in./ft.)3 = 5.16 ft3
Volumespan = N[A x L] = 4 x [16.88 x 129.00] x (12 in./ft.)3 = 5.04 ft3
Total Weight (WT) = ρw x Volumetotal = 29.10 x 5.16 = 150.0 lbs
Self Weight (WS) = ρw x Volumespan = 29.10 x 5.04 = 146.6 lbs
Distributed Self Weight (ws) = = 13.64 plf
640 plf
160 plf
ws = 13.64 plf
10.75 ft.
10.50 ft.
11.00 ft.
4475.02 lbs
4475.02 lbs
Beam Design OCKRIN
11/9/2021 3
fb = = 1114.4 psi
 fb = 1114.4 psi < Fbx' = 1437.5 psi  (CSI = 0.78)   ➜  OK
Beam Design OCKRIN
11/9/2021 4
fv* = = 80.23 psi
 fv* = 80.23 psi < Fvx' = 155.25 psi  (CSI = 0.52)   ➜  OK
fv = = 97.18 psi
 fv = 97.18 psi < Fvx' = 155.25 psi  (CSI = 0.63)   ➜  OK
Beam Design OCKRIN
11/9/2021 5
ΔLL = = 0.18 in.
(L/d)LL = 129.00 / 0.18 = 716
 ΔLL = 0.18 in = L/716 < L/360   ➜  OK
ΔTL = = 0.23 in.
(L/d)TL = 129.00 / 0.23 = 563
 ΔTL = 0.23 in = L/563 < L/240   ➜  OK
fc⊥ = = 248.6 psi
 fc⊥ = 248.6 psi < Fc⊥x' = 425.00 psi  (CSI = 0.58)   ➜  OK
Beam Design OCKRIN
11/9/2021 6
