Grade: SP No.1
Design Span (L): 7.58 ft.
Clear Span: 7.17 ft.
Total Span: 8.00 ft.
Bearing (lb): 5-3/4 in.
Live Load: 1000 plf
Dead Load: 100 plf
Selfweight: 102.9 lbs
Dist. Selfweight: 13.56 plf
Total Weight: 108.5 lbs
Beam Design 2021A646
11/9/2021 1
11/9/2021 2
= 38.58 lbs/ft3
Volumetotal = N[A x (L + lb)] = 3 x [16.88 x (91.00 + 5-3/4)] x (12 in./ft.)3 = 2.81 ft3
Volumespan = N[A x L] = 3 x [16.88 x 91.00] x (12 in./ft.)3 = 2.67 ft3
Total Weight (WT) = ρw x Volumetotal = 38.58 x 2.81 = 108.5 lbs
Self Weight (WS) = ρw x Volumespan = 38.58 x 2.67 = 102.9 lbs
Distributed Self Weight (ws) = = 13.56 plf
1000 plf
ws = 13.56 plf
7.58 ft.
7.17 ft.
4454.07 lbs
4454.07 lbs
11/9/2021 3
fb = = 1011.9 psi
 fb = 1011.9 psi < Fbx' = 1150.0 psi  (CSI = 0.88)   ➜  OK
11/9/2021 4
fv* = = 94.17 psi
 fv* = 94.17 psi < Fvx' = 195.21 psi  (CSI = 0.48)   ➜  OK
fv = = 125.10 psi
 fv = 125.10 psi < Fvx' = 195.21 psi  (CSI = 0.64)   ➜  OK
11/9/2021 5
ΔLL = = 0.10 in.
(L/d)LL = 91.00 / 0.10 = 940
 ΔLL = 0.10 in = L/940 < L/360   ➜  OK
ΔTL = = 0.11 in.
(L/d)TL = 91.00 / 0.11 = 845
 ΔTL = 0.11 in = L/845 < L/240   ➜  OK
Ab = b x lb = 1.5 x 5-3/4 = 7.50 in2
fc⊥ = = 198.0 psi
 fc⊥ = 198.0 psi < Fc⊥x' = 378.55 psi  (CSI = 0.52)   ➜  OK
11/9/2021 6
