Grade: 24F-V3 1.8E SP/SP
Size: 3.125 x 9.625
Design Span (L): 9.38 ft.
Clear Span: 9.00 ft.
Total Span: 9.75 ft.
Bearing (lb): 4.5 in.
Live Load: 600 plf
Dead Load: 300 plf
Selfweight: 72.2 lbs
Dist. Selfweight: 7.71 plf
Total Weight: 75.1 lbs
Load Duration: 1.33
CL Beam Stability Factor 0.928 - - - - -
Beam Design Josh Barlow 117 barlow acre ln Roberts Home left upper beam
11/9/2021 1
b = 3.125 in.
d = 9.625 in.
A = 3.125 x 9.625 = 30.08 in.2
Sx = (3.125)(9.625)2/6 = 48.25 in.3
Sy = (3.125)2(9.625)/6 = 15.67 in.3
Ix = (3.125)(9.625)3/12 = 232.20 in.4
Iy = (3.125)3(9.625)/12 = 24.48 in.4
11/9/2021 2
= 36.89 lbs/ft3
Volumetotal = N[A x (L + lb)] = 1 x [30.08 x (112.50 + 4.5)] x (12 in./ft.)3 = 2.04 ft3
Volumespan = N[A x L] = 1 x [30.08 x 112.50] x (12 in./ft.)3 = 1.96 ft3
Total Weight (WT) = ρw x Volumetotal = 36.89 x 2.04 = 75.1 lbs
Self Weight (WS) = ρw x Volumespan = 36.89 x 1.96 = 72.2 lbs
Distributed Self Weight (ws) = = 7.71 plf
600 plf
300 plf
  ws = 7.71 plf
9.38 ft.
9.00 ft.
9.75 ft.
4425.06 lbs
4425.06 lbs
11/9/2021 3
lu = Unbraced Length = 9.375 ft.
lu/d = = 11.69
le = 1.63lu + 3d = 1.63(112.5) + 3(9.625) = 212.25 in. = 17.69 ft.  (NDS Table 3.3.3)
Rb = = 14.46
 Rb = 14.46 < 50   ➜  OK
11/9/2021 4
FbE = = 4875.87 psi
Fbx* = Fbx(CD)(CM)(Ct) = (2400)(1.33)(1)(1) = 3192.00 psi
CL =   = 0.928
CL = 0.928 < CV = 1.0
Fbx' = (2400)(1.33)(1)(1)(0.928) = 2962.6 psi
fb = = 2480.2 psi
 fb = 2480.2 psi < Fbx' = 2962.6 psi  (CSI = 0.84)   ➜  OK
Fvx' = (300)(1.33)(1)(1) = 399.00 psi
fv* = = 175.88 psi
11/9/2021 5
 fv* = 175.88 psi < Fvx' = 399.00 psi  (CSI = 0.44)   ➜  OK
fv = = 212.19 psi
 fv = 212.19 psi < Fvx' = 399.00 psi  (CSI = 0.53)   ➜  OK
ΔLL = = 0.25 in.
(L/d)LL = 112.50 / 0.25 = 451
 ΔLL = 0.25 in = L/451 < L/360   ➜  OK
ΔTL = = 0.38 in.
(L/d)TL = 112.50 / 0.38 = 298
 ΔTL = 0.38 in = L/298 < L/240   ➜  OK
11/9/2021 6
Ab = b x lb = 3.125 x 4.5 = 14.06 in2
fc⊥ = = 314.7 psi
 fc⊥ = 314.7 psi < Fc⊥x' = 740.00 psi  (CSI = 0.43)   ➜  OK
11/9/2021 7
