Grade: 24F-V3 1.8E SP/SP
Size: 3.5 x 9.625
Design Span (L): 9.38 ft.
Clear Span: 9.00 ft.
Total Span: 9.75 ft.
Bearing (lb): 4.5 in.
Live Load: 600 plf
Dead Load: 300 plf
Selfweight: 242.7 lbs
Dist. Selfweight: 25.89 plf
Total Weight: 252.4 lbs
Load Duration: 1.33
Beam Design josh barlow Roberts Home left upper beam
11/9/2021 1
d = 9.625 in.
A = 3.500 x 9.625 = 33.69 in.2
Sx = (3.500)(9.625)2/6 = 54.04 in.3
Sy = (3.500)2(9.625)/6 = 19.65 in.3
Ix = (3.500)(9.625)3/12 = 260.07 in.4
Iy = (3.500)3(9.625)/12 = 34.39 in.4
11/9/2021 2
= 36.89 lbs/ft3
Volumetotal = N[A x (L + lb)] = 3 x [33.69 x (112.50 + 4.5)] x (12 in./ft.)3 = 6.84 ft3
Volumespan = N[A x L] = 3 x [33.69 x 112.50] x (12 in./ft.)3 = 6.58 ft3
Total Weight (WT) = ρw x Volumetotal = 36.89 x 6.84 = 252.4 lbs
Self Weight (WS) = ρw x Volumespan = 36.89 x 6.58 = 242.7 lbs
Distributed Self Weight (ws) = = 25.89 plf
600 plf
300 plf
  ws = 25.89 plf
9.38 ft.
9.00 ft.
9.75 ft.
4513.71 lbs
4513.71 lbs
11/9/2021 3
Fbx' = (2400)(1.33)(1)(1)(1.0) = 3192.0 psi
fb = = 752.9 psi
 fb = 752.9 psi < Fbx' = 3192.0 psi  (CSI = 0.24)   ➜  OK
11/9/2021 4
Fvx' = (300)(1.33)(1)(1) = 399.00 psi
fv* = = 53.39 psi
 fv* = 53.39 psi < Fvx' = 399.00 psi  (CSI = 0.13)   ➜  OK
fv = = 64.42 psi
 fv = 64.42 psi < Fvx' = 399.00 psi  (CSI = 0.16)   ➜  OK
11/9/2021 5
ΔLL = = 0.07 in.
(L/d)LL = 112.50 / 0.07 = 1515
 ΔLL = 0.07 in = L/1515 < L/240   ➜  OK
ΔTL = = 0.11 in.
(L/d)TL = 112.50 / 0.11 = 982
 ΔTL = 0.11 in = L/982 < L/180   ➜  OK
Ab = b x lb = 3.5 x 4.5 = 15.75 in2
fc⊥ = = 95.5 psi
 fc⊥ = 95.5 psi < Fc⊥x' = 740.00 psi  (CSI = 0.13)   ➜  OK
11/9/2021 6
