Design Span (L): 21.75 ft.
Clear Span: 21.50 ft.
Total Span: 22.00 ft.
Live Load: 30 plf
Dead Load: 30 plf
Selfweight: 143.4 lbs
Dist. Selfweight: 6.59 plf
Total Weight: 145.0 lbs
Beam Design 2021A643
11/8/2021 1
11/8/2021 2
Volumetotal = N[A x (L + lb)] = 2 x [13.88 x (261.00 + 3)] x (12 in./ft.)3 = 4.24 ft3
Volumespan = N[A x L] = 2 x [13.88 x 261.00] x (12 in./ft.)3 = 4.19 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 4.24 = 145.0 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 4.19 = 143.4 lbs
30 plf
30 plf
ws = 6.59 plf
21.75 ft.
21.50 ft.
22.00 ft.
732.50 lbs
732.50 lbs
11/8/2021 3
fb = = 1104.5 psi
 fb = 1104.5 psi < Fbx' = 1138.5 psi  (CSI = 0.97)   ➜  OK
11/8/2021 4
fv* = = 36.37 psi
 fv* = 36.37 psi < Fvx' = 207.00 psi  (CSI = 0.18)   ➜  OK
fv = = 39.14 psi
 fv = 39.14 psi < Fvx' = 207.00 psi  (CSI = 0.19)   ➜  OK
11/8/2021 5
ΔLL = = 0.48 in.
(L/d)LL = 261.00 / 0.48 = 547
 ΔLL = 0.48 in = L/547 < L/360   ➜  OK
ΔTL = = 1.06 in.
(L/d)TL = 261.00 / 1.06 = 246
 ΔTL = 1.06 in = L/246 < L/240   ➜  OK
fc⊥ = = 81.4 psi
 fc⊥ = 81.4 psi < Fc⊥x' = 625.00 psi  (CSI = 0.13)   ➜  OK
11/8/2021 6
