Design Span (L): 7.75 ft.
Clear Span: 7.50 ft.
Total Span: 8.00 ft.
Live Load: 53 plf
Dead Load: 20 plf
Selfweight: 15.2 lbs
Dist. Selfweight: 1.96 plf
Total Weight: 15.7 lbs
Beam Design floor joist calc
11/6/2021 1
11/6/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [8.25 x (93.00 + 3)] x (12 in./ft.)3 = 0.46 ft3
Volumespan = N[A x L] = 1 x [8.25 x 93.00] x (12 in./ft.)3 = 0.44 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 0.46 = 15.7 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 0.44 = 15.2 lbs
53 plf
20 plf
ws = 1.96 plf
7.75 ft.
7.50 ft.
299.84 lbs
299.84 lbs
11/6/2021 3
fb = = 893.0 psi
 fb = 893.0 psi < Fbx' = 1170.0 psi  (CSI = 0.76)   ➜  OK
11/6/2021 4
fv* = = 46.57 psi
 fv* = 46.57 psi < Fvx' = 180.00 psi  (CSI = 0.26)   ➜  OK
fv = = 52.81 psi
 fv = 52.81 psi < Fvx' = 180.00 psi  (CSI = 0.29)   ➜  OK
11/6/2021 5
ΔLL = = 0.13 in.
(L/d)LL = 93.00 / 0.13 = 719
 ΔLL = 0.13 in = L/719 < L/360   ➜  OK
ΔTL = = 0.18 in.
(L/d)TL = 93.00 / 0.18 = 509
 ΔTL = 0.18 in = L/509 < L/240   ➜  OK
fc⊥ = = 66.6 psi
 fc⊥ = 66.6 psi < Fc⊥x' = 625.00 psi  (CSI = 0.11)   ➜  OK
11/6/2021 6
