Grade: 24F-V3 1.8E SP/SP
Size: 3.5 x 9.625
Design Span (L): 15.50 ft.
Clear Span: 15.25 ft.
Total Span: 15.75 ft.
Selfweight: 133.8 lbs
Dist. Selfweight: 8.63 plf
Total Weight: 135.9 lbs
Beam Design 2021A637
11/4/2021 1
d = 9.625 in.
A = 3.500 x 9.625 = 33.69 in.2
Sx = (3.500)(9.625)2/6 = 54.04 in.3
Sy = (3.500)2(9.625)/6 = 19.65 in.3
Ix = (3.500)(9.625)3/12 = 260.07 in.4
Iy = (3.500)3(9.625)/12 = 34.39 in.4
11/4/2021 2
= 36.89 lbs/ft3
Volumetotal = N[A x (L + lb)] = 1 x [33.69 x (186.00 + 3)] x (12 in./ft.)3 = 3.68 ft3
Volumespan = N[A x L] = 1 x [33.69 x 186.00] x (12 in./ft.)3 = 3.63 ft3
Total Weight (WT) = ρw x Volumetotal = 36.89 x 3.68 = 135.9 lbs
Self Weight (WS) = ρw x Volumespan = 36.89 x 3.63 = 133.8 lbs
Distributed Self Weight (ws) = = 8.63 plf
  ws = 8.63 plf
15.50 ft.
15.25 ft.
15.75 ft.
1446.09 lbs
1446.09 lbs
11/4/2021 3
fb = = 1224.6 psi
 fb = 1224.6 psi < Fbx' = 2760.0 psi  (CSI = 0.44)   ➜  OK
11/4/2021 4
fv* = = 56.81 psi
 fv* = 56.81 psi < Fvx' = 345.00 psi  (CSI = 0.16)   ➜  OK
fv = = 63.37 psi
 fv = 63.37 psi < Fvx' = 345.00 psi  (CSI = 0.18)   ➜  OK
11/4/2021 5
ΔLL = = 0.28 in.
(L/d)LL = 186.00 / 0.28 = 670
 ΔLL = 0.28 in = L/670 < L/360   ➜  OK
ΔTL = = 0.51 in.
(L/d)TL = 186.00 / 0.51 = 365
 ΔTL = 0.51 in = L/365 < L/240   ➜  OK
fc⊥ = = 137.7 psi
 fc⊥ = 137.7 psi < Fc⊥x' = 740.00 psi  (CSI = 0.19)   ➜  OK
11/4/2021 6
