Design Span (L): 5.75 ft.
Clear Span: 5.50 ft.
Total Span: 6.00 ft.
Live Load: 60 plf
Dead Load: 300 plf
Selfweight: 35.1 lbs
Dist. Selfweight: 6.10 plf
Total Weight: 36.6 lbs
Incised Lumber: Yes
Beam Design 2021A633
10/29/2021 1
10/29/2021 2
Volumetotal = N[A x (L + lb)] = 3 x [8.25 x (69.00 + 3)] x (12 in./ft.)3 = 1.03 ft3
Volumespan = N[A x L] = 3 x [8.25 x 69.00] x (12 in./ft.)3 = 0.99 ft3
Total Weight (WT) = ρw x Volumetotal = 35.47 x 1.03 = 36.6 lbs
Self Weight (WS) = ρw x Volumespan = 35.47 x 0.99 = 35.1 lbs
Distributed Self Weight (ws) = = 6.10 plf
60 plf
300 plf
ws = 6.10 plf
5.75 ft.
5.50 ft.
1098.29 lbs
1098.29 lbs
10/29/2021 3
lu = Unbraced Length = 5.750 ft.
lu/d = = 12.55
le = 1.63lu + 3d = 1.63(69.0) + 3(5.5) = 128.97 in. = 10.75 ft.  (NDS Table 3.3.3)
Rb = = 5.92
 Rb = 5.92 < 50   ➜  OK
10/29/2021 4
Eminy' = Eminy(CM)(Ct)(Ci) = 580000(0.9)(1)(0.95) = 495900 psi
FbE = = 16988.26 psi
Fbx* = Fbx(CD)(CM)(Ct)(CF)(Ci)(Cr) = (900)(1.15)(0.85)(1)(1.3)(0.8)(1) = 914.94 psi
CL =   = 0.997
Fbx' = (900)(1.15)(0.85)(1)(0.997)(1.3)(0.8)(1) = 912.4 psi
fb = = 800.3 psi
 fb = 800.3 psi < Fbx' = 912.4 psi  (CSI = 0.88)   ➜  OK
fv* = = 53.62 psi
 fv* = 53.62 psi < Fvx' = 160.63 psi  (CSI = 0.33)   ➜  OK
fv = = 63.79 psi
 fv = 63.79 psi < Fvx' = 160.63 psi  (CSI = 0.40)   ➜  OK
10/29/2021 5
ΔLL = = 0.02 in.
(L/d)LL = 69.00 / 0.02 = 3991
 ΔLL = 0.02 in = L/3991 < L/360   ➜  OK
ΔTL = = 0.11 in.
(L/d)TL = 69.00 / 0.11 = 654
 ΔTL = 0.11 in = L/654 < L/240   ➜  OK
fc⊥ = = 81.4 psi
 fc⊥ = 81.4 psi < Fc⊥x' = 418.75 psi  (CSI = 0.19)   ➜  OK
10/29/2021 6
