Beam Design - Low Bridge
Design Span (L): 5.75 ft.
Clear Span: 5.50 ft.
Total Span: 6.00 ft.
Live Load: 200 plf
Dead Load: 20 plf
Selfweight: 23.4 lbs
Dist. Selfweight: 4.06 plf
Total Weight: 24.4 lbs
Defl. Limits: 720|480
Load Duration: 1.60
Beam Design Coleman Creek RR 000
10/27/2021 1
10/27/2021 2
Volumetotal = N[A x (L + lb)] = 2 x [8.25 x (69.02 + 3)] x (12 in./ft.)3 = 0.69 ft3
Volumespan = N[A x L] = 2 x [8.25 x 69.02] x (12 in./ft.)3 = 0.66 ft3
Total Weight (WT) = ρw x Volumetotal = 35.47 x 0.69 = 24.4 lbs
Self Weight (WS) = ρw x Volumespan = 35.47 x 0.66 = 23.4 lbs
Distributed Self Weight (ws) = = 4.06 plf
200 plf
20 plf
ws = 4.06 plf
5.75 ft.
5.50 ft.
672.42 lbs
672.42 lbs
10/27/2021 3
lu/d = = 4.36
Rb = = 5.50
 Rb = 5.50 < 50   ➜  OK
10/27/2021 4
Eminy' = Eminy(CM)(Ct)(Ci) = 580000(0.9)(1)(1) = 522000 psi
FbE = = 20732.57 psi
Fbx* = Fbx(CD)(CM)(Ct)(CF)(Ci)(Cr) = (900)(1.60)(0.85)(1)(1.3)(1)(1) = 1591.20 psi
CL =   = 0.996
Fbx' = (900)(1.60)(0.85)(1)(0.996)(1.3)(1)(1) = 1584.6 psi
fb = = 735.2 psi
 fb = 735.2 psi < Fbx' = 1584.6 psi  (CSI = 0.46)   ➜  OK
Fvx' = (180)(1.60)(0.97)(1)(1) = 279.36 psi
fv* = = 49.25 psi
 fv* = 49.25 psi < Fvx' = 279.36 psi  (CSI = 0.18)   ➜  OK
fv = = 58.58 psi
 fv = 58.58 psi < Fvx' = 279.36 psi  (CSI = 0.21)   ➜  OK
10/27/2021 5
LL Allowable: L/720
TL Allowable: L/480
ΔLL = = 0.08 in.
(L/d)LL = 69.02 / 0.08 = 839
 ΔLL = 0.08 in = L/839 < L/720   ➜  OK
ΔTL = = 0.09 in.
(L/d)TL = 69.02 / 0.09 = 749
 ΔTL = 0.09 in = L/749 < L/480   ➜  OK
fc⊥ = = 74.7 psi
 fc⊥ = 74.7 psi < Fc⊥x' = 418.75 psi  (CSI = 0.18)   ➜  OK
10/27/2021 6
