Grade: DF No.1
Size: 4 x 14
Design Span (L): 9.75 ft.
Clear Span: 9.50 ft.
Total Span: 10.00 ft.
Live Load: 210 plf
Dead Load: 280 plf
Selfweight: 107.4 lbs
Dist. Selfweight: 11.02 plf
Total Weight: 110.2 lbs
Load Duration: 1.25
Incised Lumber: Yes
Beam Design 2021A63
1/16/2021 1
d = 13.250 in.
Beam Design 2021A63
1/16/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [46.38 x (117.00 + 3)] x (12 in./ft.)3 = 3.22 ft3
Volumespan = N[A x L] = 1 x [46.38 x 117.00] x (12 in./ft.)3 = 3.14 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 3.22 = 110.2 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 3.14 = 107.4 lbs
Distributed Self Weight (ws) = = 11.02 plf
210 plf
280 plf
ws = 11.02 plf
9.75 ft.
9.50 ft.
10.00 ft.
2505.08 lbs
2505.08 lbs
Beam Design 2021A63
1/16/2021 3
Fbx' = (1000)(1.25)(1)(1)(1)(1)(0.8)(1.15) = 1150.0 psi
fb = = 697.6 psi
 fb = 697.6 psi < Fbx' = 1150.0 psi  (CSI = 0.61)   ➜  OK
Beam Design 2021A63
1/16/2021 4
Fvx' = (180)(1.25)(1)(1)(0.8) = 180.00 psi
fv* = = 61.11 psi
 fv* = 61.11 psi < Fvx' = 180.00 psi  (CSI = 0.34)   ➜  OK
fv = = 79.00 psi
 fv = 79.00 psi < Fvx' = 180.00 psi  (CSI = 0.44)   ➜  OK
Ex' = Ex(CM)(Ct)(Ci) = 1700000(1)(1)(0.95) = 1615000 psi
Beam Design 2021A63
1/16/2021 5
ΔLL = = 0.04 in.
(L/d)LL = 117.00 / 0.04 = 3002
 ΔLL = 0.04 in = L/3002 < L/360   ➜  OK
ΔTL = = 0.09 in.
(L/d)TL = 117.00 / 0.09 = 1258
 ΔTL = 0.09 in = L/1258 < L/240   ➜  OK
fc⊥ = = 238.6 psi
 fc⊥ = 238.6 psi < Fc⊥x' = 625.00 psi  (CSI = 0.38)   ➜  OK
Beam Design 2021A63
1/16/2021 6
