Size: 5.5 x 18
Design Span (L): 26.25 ft.
Clear Span: 26.00 ft.
Total Span: 26.50 ft.
Live Load: 400 plf
Dead Load: 100 plf
Selfweight: 609.3 lbs
Dist. Selfweight: 23.21 plf
Total Weight: 615.1 lbs
CV Volume Factor 0.932b - - - - -
Beam Design 2021A617
10/25/2021 1
d = 18.000 in.
10/25/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [99.00 x (315.00 + 3)] x (12 in./ft.)3 = 18.22 ft3
Volumespan = N[A x L] = 1 x [99.00 x 315.00] x (12 in./ft.)3 = 18.05 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 18.22 = 615.1 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 18.05 = 609.3 lbs
400 plf
  ws = 23.21 plf
26.25 ft.
26.00 ft.
26.50 ft.
6932.54 lbs
6932.54 lbs
10/25/2021 3
CV = = 0.932
CV = 0.932 < CL = 1
Fbx' = (2400)(1.15)(1)(1)(0.932) = 2573.6 psi
fb = = 1820.8 psi
 fb = 1820.8 psi < Fbx' = 2573.6 psi  (CSI = 0.71)   ➜  OK
10/25/2021 4
fv* = = 92.16 psi
 fv* = 92.16 psi < Fvx' = 304.75 psi  (CSI = 0.30)   ➜  OK
fv = = 104.05 psi
 fv = 104.05 psi < Fvx' = 304.75 psi  (CSI = 0.34)   ➜  OK
10/25/2021 5
ΔLL = = 0.89 in.
(L/d)LL = 315.00 / 0.89 = 355
 ΔLL = 0.89 in = L/355 > L/360   ➜  NG
ΔTL = = 1.16 in.
(L/d)TL = 315.00 / 1.16 = 271
 ΔTL = 1.16 in = L/271 < L/240   ➜  OK
fc⊥ = = 420.2 psi
 fc⊥ = 420.2 psi < Fc⊥x' = 650.00 psi  (CSI = 0.65)   ➜  OK
10/25/2021 6
