Beam Design - Ron Wolf
Design Span (L): 11.58 ft.
Clear Span: 11.33 ft.
Total Span: 11.83 ft.
Dead Load: 57 plf
Selfweight: 76.3 lbs
Dist. Selfweight: 6.59 plf
Total Weight: 78.0 lbs
Beam Design Anderson 2021A611
10/21/2021 1
10/21/2021 2
Volumetotal = N[A x (L + lb)] = 2 x [13.88 x (138.96 + 3)] x (12 in./ft.)3 = 2.28 ft3
Volumespan = N[A x L] = 2 x [13.88 x 138.96] x (12 in./ft.)3 = 2.23 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 2.28 = 78.0 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 2.23 = 76.3 lbs
57 plf
ws = 6.59 plf
11.58 ft.
11.33 ft.
11.83 ft.
967.64 lbs
967.64 lbs
10/21/2021 3
fb = = 769.2 psi
 fb = 769.2 psi < Fbx' = 990.0 psi  (CSI = 0.78)   ➜  OK
10/21/2021 4
fv* = = 44.38 psi
 fv* = 44.38 psi < Fvx' = 180.00 psi  (CSI = 0.25)   ➜  OK
fv = = 51.20 psi
 fv = 51.20 psi < Fvx' = 180.00 psi  (CSI = 0.28)   ➜  OK
10/21/2021 5
ΔLL = = 0.13 in.
(L/d)LL = 138.96 / 0.13 = 1087
 ΔLL = 0.13 in = L/1087 < L/360   ➜  OK
ΔTL = = 0.21 in.
(L/d)TL = 138.96 / 0.21 = 665
 ΔTL = 0.21 in = L/665 < L/240   ➜  OK
fc⊥ = = 107.5 psi
 fc⊥ = 107.5 psi < Fc⊥x' = 625.00 psi  (CSI = 0.17)   ➜  OK
10/21/2021 6
