Grade: DF No.1
Size: 4 x 12
Design Span (L): 10.75 ft.
Clear Span: 10.50 ft.
Total Span: 11.00 ft.
Live Load: 128 plf
Dead Load: 128 plf
Selfweight: 100.5 lbs
Dist. Selfweight: 9.35 plf
Total Weight: 102.9 lbs
Load Duration: 1.25
Incised Lumber: Yes
CF Size Factor 1.1 1 - 1 - -
Beam Design 2021A61
1/16/2021 1
Beam Design 2021A61
1/16/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [39.38 x (129.00 + 3)] x (12 in./ft.)3 = 3.01 ft3
Volumespan = N[A x L] = 1 x [39.38 x 129.00] x (12 in./ft.)3 = 2.94 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 3.01 = 102.9 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 2.94 = 100.5 lbs
128 plf
128 plf
ws = 9.35 plf
10.75 ft.
10.50 ft.
11.00 ft.
1459.44 lbs
1459.44 lbs
Beam Design 2021A61
1/16/2021 3
Fbx' = (1000)(1.25)(1)(1)(1)(1.1)(0.8)(1.15) = 1265.0 psi
fb = = 623.0 psi
 fb = 623.0 psi < Fbx' = 1265.0 psi  (CSI = 0.49)   ➜  OK
Beam Design 2021A61
1/16/2021 4
Fvx' = (180)(1.25)(1)(1)(0.8) = 180.00 psi
fv* = = 44.86 psi
 fv* = 44.86 psi < Fvx' = 180.00 psi  (CSI = 0.25)   ➜  OK
fv = = 54.33 psi
 fv = 54.33 psi < Fvx' = 180.00 psi  (CSI = 0.30)   ➜  OK
Ex' = Ex(CM)(Ct)(Ci) = 1700000(1)(1)(0.95) = 1615000 psi
Beam Design 2021A61
1/16/2021 5
ΔLL = = 0.06 in.
(L/d)LL = 129.00 / 0.06 = 2249
 ΔLL = 0.06 in = L/2249 < L/360   ➜  OK
ΔTL = = 0.12 in.
(L/d)TL = 129.00 / 0.12 = 1085
 ΔTL = 0.12 in = L/1085 < L/240   ➜  OK
fc⊥ = = 139.0 psi
 fc⊥ = 139.0 psi < Fc⊥x' = 625.00 psi  (CSI = 0.22)   ➜  OK
Beam Design 2021A61
1/16/2021 6
