Size: 4 x 10
Design Span (L): 15.67 ft.
Clear Span: 15.33 ft.
Total Span: 16.00 ft.
Bearing (lb): 4 in.
Live Load: 100 lbs
Dead Load: 75 lbs
Selfweight: 120.5 lbs
Dist. Selfweight: 7.69 plf
Total Weight: 123.0 lbs
Lateral Support: 8' o/c
CL Beam Stability Factor 0.984 - - - - -
Beam Design 2021A609
10/16/2021 1
10/16/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [32.38 x (188.00 + 4)] x (12 in./ft.)3 = 3.60 ft3
Volumespan = N[A x L] = 1 x [32.38 x 188.00] x (12 in./ft.)3 = 3.52 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 3.60 = 123.0 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 3.52 = 120.5 lbs
100 lbs
75 lbs
ws = 7.69 plf
15.67 ft.
15.33 ft.
149.02 lbs
149.02 lbs
10/16/2021 3
lu = Unbraced Length = 8 ft.
lu/d = = 10.38
le = 1.63lu + 3d = 1.63(96.0) + 3(9.25) = 184.23 in. = 15.35 ft.  (NDS Table 3.3.3)
Rb = = 11.79
 Rb = 11.79 < 50   ➜  OK
10/16/2021 4
FbE = = 5003.15 psi
Fbx* = Fbx(CD)(CM)(Ct)(CF)(Ci)(Cr) = (900)(1.15)(1)(1)(1.2)(1)(1) = 1242.00 psi
CL =   = 0.984
Fbx' = (900)(1.15)(1)(1)(0.984)(1.2)(1)(1) = 1222.2 psi
fb = = 221.5 psi
 fb = 221.5 psi < Fbx' = 1222.2 psi  (CSI = 0.18)   ➜  OK
fv* = = 6.57 psi
 fv* = 6.57 psi < Fvx' = 207.00 psi  (CSI = 0.03)   ➜  OK
fv = = 6.85 psi
 fv = 6.85 psi < Fvx' = 207.00 psi  (CSI = 0.03)   ➜  OK
10/16/2021 5
ΔLL =   =   = 0.04 in.
(L/d)LL = 188.00 / 0.04 = 5016
 ΔLL = 0.04 in = L/5016 < L/360   ➜  OK
ΔTL =   =   = 0.09 in.
(L/d)TL = 188.00 / 0.09 = 2004
 ΔTL = 0.09 in = L/2004 < L/240   ➜  OK
Ab = b x lb = 3.5 x 4 = 14.00 in2
fc⊥ = = 10.6 psi
 fc⊥ = 10.6 psi < Fc⊥x' = 625.00 psi  (CSI = 0.02)   ➜  OK
10/16/2021 6
