Grade: SPF No.2
Design Span (L): 8.75 ft.
Clear Span: 8.50 ft.
Total Span: 9.00 ft.
Selfweight: 59.7 lbs
Dist. Selfweight: 6.82 plf
Total Weight: 61.4 lbs
Beam Design 2021A607
10/15/2021 1
10/15/2021 2
Volumetotal = N[A x (L + lb)] = 2 x [16.88 x (105.00 + 3)] x (12 in./ft.)3 = 2.11 ft3
Volumespan = N[A x L] = 2 x [16.88 x 105.00] x (12 in./ft.)3 = 2.05 ft3
Total Weight (WT) = ρw x Volumetotal = 29.10 x 2.11 = 61.4 lbs
Self Weight (WS) = ρw x Volumespan = 29.10 x 2.05 = 59.7 lbs
ws = 6.82 plf
8.75 ft.
8.50 ft.
9.00 ft.
818.19 lbs
818.19 lbs
10/15/2021 3
fb = = 330.0 psi
 fb = 330.0 psi < Fbx' = 1006.2 psi  (CSI = 0.33)   ➜  OK
10/15/2021 4
fv* = = 27.78 psi
 fv* = 27.78 psi < Fvx' = 155.25 psi  (CSI = 0.18)   ➜  OK
fv = = 35.35 psi
 fv = 35.35 psi < Fvx' = 155.25 psi  (CSI = 0.23)   ➜  OK
10/15/2021 5
ΔLL = = 0.03 in.
(L/d)LL = 105.00 / 0.03 = 3967
 ΔLL = 0.03 in = L/3967 < L/180   ➜  OK
ΔTL = = 0.05 in.
(L/d)TL = 105.00 / 0.05 = 2182
 ΔTL = 0.05 in = L/2182 < L/120   ➜  OK
fc⊥ = = 90.9 psi
 fc⊥ = 90.9 psi < Fc⊥x' = 425.00 psi  (CSI = 0.21)   ➜  OK
10/15/2021 6
