Design Span (L): 6.75 ft.
Clear Span: 6.50 ft.
Total Span: 7.00 ft.
Live Load: 53.2 plf
Dead Load: 16 plf
Selfweight: 17.4 lbs
Dist. Selfweight: 2.58 plf
Total Weight: 18.1 lbs
Beam Design 2021A606
10/12/2021 1
10/12/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [10.88 x (81.00 + 3)] x (12 in./ft.)3 = 0.53 ft3
Volumespan = N[A x L] = 1 x [10.88 x 81.00] x (12 in./ft.)3 = 0.51 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 0.53 = 18.1 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 0.51 = 17.4 lbs
53.2 plf
16 plf
ws = 2.58 plf
6.75 ft.
6.50 ft.
7.00 ft.
251.24 lbs
251.24 lbs
10/12/2021 3
fb = = 373.3 psi
 fb = 373.3 psi < Fbx' = 1242.0 psi  (CSI = 0.30)   ➜  OK
10/12/2021 4
fv* = = 27.43 psi
 fv* = 27.43 psi < Fvx' = 207.00 psi  (CSI = 0.13)   ➜  OK
fv = = 33.42 psi
 fv = 33.42 psi < Fvx' = 207.00 psi  (CSI = 0.16)   ➜  OK
10/12/2021 5
ΔLL = = 0.03 in.
(L/d)LL = 81.00 / 0.03 = 2484
 ΔLL = 0.03 in = L/2484 < L/360   ➜  OK
ΔTL = = 0.04 in.
(L/d)TL = 81.00 / 0.04 = 1841
 ΔTL = 0.04 in = L/1841 < L/240   ➜  OK
fc⊥ = = 55.8 psi
 fc⊥ = 55.8 psi < Fc⊥x' = 625.00 psi  (CSI = 0.09)   ➜  OK
10/12/2021 6
