Beam Design - DIAGRAM 3
Design Span (L): 11.63 ft.
Clear Span: 11.25 ft.
Bearing (lb): 4.5 in.
Selfweight: 68.3 lbs
Dist. Selfweight: 5.88 plf
Total Weight: 70.5 lbs
Beam Design 1010 PINE STREET ZAIK
10/12/2021 1
10/12/2021 2
Volumetotal = N[A x (L + lb)] = 3 x [8.25 x (139.50 + 4.5)] x (12 in./ft.)3 = 2.06 ft3
Volumespan = N[A x L] = 3 x [8.25 x 139.50] x (12 in./ft.)3 = 2.00 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 2.06 = 70.5 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 2.00 = 68.3 lbs
Distributed Self Weight (ws) = = 5.88 plf
ws = 5.88 plf
11.63 ft.
11.25 ft.
1085.27 lbs
1085.27 lbs
10/12/2021 3
fb = = 1616.1 psi
 fb = 1616.1 psi > Fbx' = 1345.5 psi  (CSI = 1.20)   ➜  NG
10/12/2021 4
fv* = = 58.69 psi
 fv* = 58.69 psi < Fvx' = 207.00 psi  (CSI = 0.28)   ➜  OK
fv = = 63.72 psi
 fv = 63.72 psi < Fvx' = 207.00 psi  (CSI = 0.31)   ➜  OK
10/12/2021 5
ΔLL = = 0.41 in.
(L/d)LL = 139.50 / 0.41 = 339
 ΔLL = 0.41 in = L/339 > L/360   ➜  NG
ΔTL = = 0.74 in.
(L/d)TL = 139.50 / 0.74 = 187
 ΔTL = 0.74 in = L/187 > L/240   ➜  NG
Ab = b x lb = 1.5 x 4.5 = 6.75 in2
fc⊥ = = 53.6 psi
 fc⊥ = 53.6 psi < Fc⊥x' = 625.00 psi  (CSI = 0.09)   ➜  OK
10/12/2021 6
