Beam Design - DIAGRAM 2
Design Span (L): 5.72 ft.
Clear Span: 5.60 ft.
Total Span: 5.85 ft.
Bearing (lb): 1.5 in.
Selfweight: 22.4 lbs
Dist. Selfweight: 3.92 plf
Total Weight: 22.9 lbs
Beam Design 1010 PINE STREET ZAIK
10/12/2021 1
10/12/2021 2
Volumetotal = N[A x (L + lb)] = 2 x [8.25 x (68.70 + 1.5)] x (12 in./ft.)3 = 0.67 ft3
Volumespan = N[A x L] = 2 x [8.25 x 68.70] x (12 in./ft.)3 = 0.66 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 0.67 = 22.9 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 0.66 = 22.4 lbs
ws = 3.92 plf
5.72 ft.
5.60 ft.
5.85 ft.
523.34 lbs
523.34 lbs
10/12/2021 3
fb = = 581.6 psi
 fb = 581.6 psi < Fbx' = 1345.5 psi  (CSI = 0.43)   ➜  OK
10/12/2021 4
fv* = = 39.10 psi
 fv* = 39.10 psi < Fvx' = 207.00 psi  (CSI = 0.19)   ➜  OK
fv = = 46.56 psi
 fv = 46.56 psi < Fvx' = 207.00 psi  (CSI = 0.22)   ➜  OK
10/12/2021 5
ΔLL = = 0.04 in.
(L/d)LL = 68.70 / 0.04 = 1892
 ΔLL = 0.04 in = L/1892 < L/360   ➜  OK
ΔTL = = 0.06 in.
(L/d)TL = 68.70 / 0.06 = 1057
 ΔTL = 0.06 in = L/1057 < L/240   ➜  OK
fc⊥ = = 116.3 psi
 fc⊥ = 116.3 psi < Fc⊥x' = 625.00 psi  (CSI = 0.19)   ➜  OK
10/12/2021 6
